Painting Door Handles
Old Jan 1, 2009 | 04:09 PM
SilverBullet08's Avatar
SilverBullet08
Default Painting Door Handles
I was just wanting some feedback on painting the door handles. I was wanting to paint mine to match my paint. I plan on primering, painting, and clearing them. Will they still chip/flake off with use? Any advice with help. Thanks
Old Jan 1, 2009 | 05:08 PM
SeMiGoD's Avatar
SeMiGoD
As with anything, stuff can happen. The biggest key to a proper paint job is prep, prep, and more prep.
Old Jan 2, 2009 | 11:57 AM
SilverBullet08
Anymore advice???
Old Jan 2, 2009 | 12:33 PM
superdak05's Avatar
superdak05
when painting plastic, it is nesecery to mix in some type of flex agent into the mix. this will help with the wear on the handles. ever seen a painted splash guard that has spider cracks in it. that because there is no flex agent mixed into the mix. any paint supply store has it. also, to do the job correctly. remove them from the door.
Old Jan 2, 2009 | 12:34 PM
lxman1's Avatar
lxman1
Site Moderator
Most Caravans and Calibers have painted handles. Neither of mine have had any problems yet.
Old Jan 2, 2009 | 12:43 PM
dirtydog's Avatar
dirtydog
Moderate User
Big Misconception!
Flex paint is not needed if you do a proper prep job! Also, the handles don't flex like a bumper anyways. Just because they are plastic has nothing to do with anything except color match. You'll need a lighter coloered primer and a few coats before paint. Plastic just absorbs paint diff is all.
The biggest problem you have is sanding those handles smooth enough to accept paint. They are an ABS plastic that has a rough finish to them. Also, you may get minor flaking where the door handle recesses and slides out. it will rub there and cause some minor issues, but other than that. Go for it.
Old Jan 2, 2009 | 01:16 PM
SilverBullet08
ok thanks for the input. i planned on buying some new ones just to use them as a test run to make sure it will look right.
Old Jan 2, 2009 | 02:30 PM
Got_Hemi44's Avatar
Got_Hemi44
I've been wanting to paint mine red. I was thinking about buying those plastic chrome covers and just painting them instead.
Old Jan 2, 2009 | 02:59 PM
SilverBullet08
would that be easier to paint on then the factory ones?
Old Jan 2, 2009 | 05:39 PM
mdram43's Avatar
mdram43
it'll chip off. just like on chevy avalanches. ive seen people get the plastic painted and then it flakes off.
