Leveling Kit ??
I can't really tell if my 06 Mega Cab is dipping in the front, i see most people getting the leveling kit, to fit "35" tires on there quad cabs and mega cabs. Either i am blind or i can't see mine dipping in the front, for the most part it looks level.... I would like to move up to 35's in the summer.... Is there a bargain body lift kit out there for the dodge 4x4's???
Check out Fat Bob's Garage for leveling kits. If you level just the front, the kit is not very expensive - about $40 - $60 for the spacers. But you have to install it or pay someone to have it installed. Once installed, you will need to get a front end alignment.
Overall, not too shabby though.
yeah i got my leveling kit from fat bob's, went with the steel level though not polyurethane. also installed it myself and did have it aligned. your megacab may not look as if it is dipping in the front but it is. my brother put a leveling kit on his 2500 quad cab and his truck looks as if it sits higher up than mine but it does not. that is because our trucks are so much more longer it is tuffer to see. but trust me it dips. parked next to bosses megacab and can see leveled versus not leveled.
does the megecab have the 2500 suspension? th ebest leveling kits are the steel or aluminum spacers that sit on top of the strut assembly no need to take the spring/strut assembly apart for this. these spacers should only take 2 hours at the most to install and are easy todo with no special tools ( do not need spring compressor). the other spacers that sit on top of the spring but under the strut assembly top plate are more of a pain in the a$$ to install as you need a spring compressor and have to take apart the whole strut assembly to do it. if you can find the steel ones get those.
rssjib they are seeling the topguncustomz.com 2.5 steel spacers for 479.99 for your truck right now you should get them. dont get the daystar urethanes. youll be better off with the steel ones.
and yes yuo can fit 35s on there with justthe leveling kit. going the body lift/leveling kit would be cheaper way to get lift than a suspension lift too. performance accessories makes the body lift for you truck that would lift it 3 inches for around $450-$500. you will always want wheel well liners to hide the ugly look of the frame which are a few hundred.
You prob don't motice anything because you've got so much crap hanging off your truck in extras...lol j/k
I like the stance of factory. I think the leveling kit puts the front too high actually. Then when you put so much as a screwdriver in the bed, the truck looks like it has 1,000#'s back there. Not really, but you get my drift.
If you don't notice it, leave it be. If you want a nice cheap look and fit 35's, I would suggest getting a 3" body lift. They are super cheap, it will set your truck up in the air and allow you to run your 35's.
I have seen a few people that want to get better mpg's out of their ram yet they get a leveling kit?WTF? Dodge actually had testing done and proved that even 1" lift in the fron created a loss of 1mpg at highway speeds. That's why use of airbags when towing a trailer is very beneficial.
thats why you get helper springs in the back too
.... mine doesnt sag that much with my crf450 in the back at all.
and the ones that get mods to "help mpgs" are denying the fact they want there truck to perform better. nobody buys a truck with mpgs in mind and if you do theres something wrong there. i mean sure id love it if my truck could get 25 MPGs but it aint going to happen and im ok with that. im happy to see 15 on most days and i have all the bolt on thats people get and say they get it because it helps mpgs. the sc 3815 helped the mpgs the best haha maybe 1-1.5 mpgs better...
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
Trending Topics
My buddy has helpers and his truck rides like a shortbox 3500 if there was such a thing!
I have 250#'s of sand in my bed for the winter. Can't even notice any sag until you get over 300 or so then it starts to tilt sligthly. Your bike is prob no more than 600lbs, so your fine without. Actually, I bet your truck sits like it has a leveling kit when your bike is back there....lol
