Installed my Hellas???
Old Mar 21, 2009 | 11:56 PM
  #31
Rebeltilldeath3's Avatar
Rebeltilldeath3
Originally Posted by SilverBullet08
u mean the switch or the relay. i have the green wire and yellow wire in the switch
I mean on the switch. The color of the wire does not tell me anything.
Old Mar 22, 2009 | 12:01 AM
  #32
Alpheus's Avatar
Alpheus
tell me what wire is runnin where I can help you if you give me that info...
Old Mar 22, 2009 | 12:07 AM
  #33
SilverBullet08's Avatar
SilverBullet08
alright.
red wire from pos. battery to the correct spot on the relay
green wire. from relay to middle slot on the rocker switch
black wire connecting the two lights then to the relay
blue wire connect to the lamp and grounding on the crossmember where i mounted them on.
yellow wire from the relay to the switch
Old Mar 22, 2009 | 12:11 AM
  #34
Alpheus's Avatar
Alpheus
Is this how you have the wires running?
Old Mar 22, 2009 | 12:12 AM
  #35
Alpheus's Avatar
Alpheus
alright.
Where is the ground for your relay # 85???
Old Mar 22, 2009 | 12:14 AM
  #36
Rebeltilldeath3
Uh, 85 should be ground and 86 should be switch. That diagram can't be right.
Old Mar 22, 2009 | 12:16 AM
  #37
Alpheus's Avatar
Alpheus
Dont pay attention to diagram just run your 85 to ground...
Old Mar 22, 2009 | 12:17 AM
  #38
SilverBullet08
my green wire is just from the relay to the switch not to the headlights and i think i have the green wire in the middle of the rocker switch and no ground wire for my relay. everything else is the same
Old Mar 22, 2009 | 12:19 AM
  #39
Rebeltilldeath3
The relay has to have ground or it won't work.
I was going to ask where the 4th wire on your relay was, but thought it was hidden from view.
  #40
Alpheus's Avatar
Alpheus
OK your relay must be grounded to activate the switch inside the relay. The diagram is wired different than your truck. From what you have told me your relay is not working and I think its the ground...
