A/C Purge and Refill Question
Old 03-25-2009, 02:34 PM
cpukramer's Avatar
cpukramer
cpukramer is offline
anytime .... How bad is yours leaking? If it isn't leaking too bad, you can try some radiator stop-leak. The pellets actually work pretty good. The OEM heater cores are welded and sometimes the seams can spring a leak. The stop-leak does a good job at fixing that. Mine had a large hole that was not fixable. The aftermarket cores are stamped - much better quality.
Old 03-25-2009, 03:08 PM
Seanutz's Avatar
Seanutz
Seanutz is offline
Leaking bad, to the point that Id have to carry a gallon of water to put in the radiator at least once a day. The passenger side floor was constantly soaked. Im just not looking forward to pulling the dash... I want someone else to do it for me but I dont have that kinda ka-ching...
Old 03-25-2009, 03:19 PM
cpukramer's Avatar
cpukramer
i hears ya .... sounds like the stop leak is a no-go for you. Sorry man ... but at least you will have excellent heat and a dry interior when you are done!!
Old 03-25-2009, 09:56 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
If you empty/open the system, you need to vacuum the system down to 29.92" vacuum. This boils all of the moisture out of the system. If not, icing can form in the expansion valve/orifice tube (depending on system) which will block the flow of refrigerant and put a lot of strain on the system.
Old 03-26-2009, 10:22 AM
galvatron's Avatar
galvatron
galvatron is offline
the system can't be "purged". it must be vac'd first then charged. and trying to bleed the system's high side while running is dangerous and the best part is the system has oil in it which will go everywhere when aerosolized, no fun to clean up.
Old 03-26-2009, 11:07 AM
cpukramer's Avatar
cpukramer
Thanks for the advice ... I will let me friend know, I am assuming he will know what that means!!
Old 03-26-2009, 05:27 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
If not, get a new friend
Quick Reply: A/C Purge and Refill Question
