E-FAN tell me what you guys thinks about this one.
Old Apr 26, 2009 | 08:33 PM
  #51
RubberFrog's Avatar
RubberFrog
Originally Posted by dedogg
RFog you are a mad man. If you havent had any cooling issues I think this is the way I am gonna go, I like the fact that the fan covers the entire rad instead of a portion of it. I am just gonna have to find some where to mount the bottles, the location you used is where my CAI is. Time to do some studying.
Does your cai have a heat shield? That's a great place to mount the bottles.
Old Apr 26, 2009 | 08:40 PM
  #52
RubberFrog's Avatar
RubberFrog
Here is the MarkVIII frame. It covers the radiator top to bottom and side to side. It's made from 1.5" aluminum angle. The cutout is where my tstat probe was located.
Old Apr 26, 2009 | 09:42 PM
  #53
dedogg's Avatar
dedogg
you might be right frog, i would have to take the shroud off and see how much room I have. Also the fans I am looking at on Ebay dont have the metal housing they are plastic, did you put yours on or did it only come on certain years? Here are some photos of what I got.
Old Apr 26, 2009 | 11:06 PM
  #54
RubberFrog's Avatar
RubberFrog
I made the frame.
Old Apr 27, 2009 | 12:11 AM
  #55
dedogg's Avatar
dedogg
Thanks frog, was the bracket needed for it to fit? I found one on ebay that I am looking at buying its like $50.00 so if this doesnt work the damage wont be to bad.
Old Apr 27, 2009 | 08:22 AM
  #56
RubberFrog's Avatar
RubberFrog
The bracket is what I used to mount it to the radiator. There are two holes i the top and bottom of the radiator. I just drilled brackets to match those holes and bolted it in. You can cut the aluminum with a hacksaw.
Old Apr 27, 2009 | 11:38 AM
  #57
BEAR's Avatar
BEAR
seems to me either fan would be good just depending on how you want to go.
Old Apr 27, 2009 | 12:38 PM
  #58
HammerZ71's Avatar
HammerZ71
They are good, viable alternatives. But don't forget, for you guys with doubts about being able to fab something up, that the Flex-A-Lite and Viper alternatives are out there. Obviously a bit more money, but they bolt right up to to factory shroud and can be purchased with everything you need, right down to an optional dash-mounted on/off switch to override the temp probe.
Not trying to sway anyone whose looking to do the Ford fans, just pointing out ALL the available options...
Old Apr 28, 2009 | 12:07 AM
  #59
dedogg's Avatar
dedogg
Your right hammer I have been looking at them. I caught a thread with some of your input on dodgetruck world.
Old Apr 28, 2009 | 07:30 PM
  #60
lxman1's Avatar
lxman1
Site Moderator
Anybody sized up a 08-09 Grand Caravan fan? They switched to a larger single fan in 08 vs a dual fan set-up on my 07. I haven't really looked at my dad's 08 to see what it looks like other than I noticed it was single.
