E-FAN tell me what you guys thinks about this one.
Old Apr 28, 2009 | 07:38 PM
  #61
Off_Road_Teacher's Avatar
Off_Road_Teacher
For anyone who is worried about the 3.8 fan pulling enough air to keep the truck cool, I sat in traffic yesterday going into Philly on 76 for 2 hours in 95 degree heat and the temp never moved. I have also made a good number of back to back 1/4 mile runs with this fan and same thing, the gauge never moves. The only thing I would ever worry about with this fan is towing, then I might need to hook it up to high.
Old Apr 28, 2009 | 09:53 PM
  #62
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
that's convincing enough for me. gonna go to the local pick n pull and see if i can't find one. alpheus, care to send a couple relays my way?
Old May 22, 2009 | 06:18 PM
  #63
azlodaniel1's Avatar
azlodaniel1
Off_Road_Teacher Is there anyway that you could post a picture of yours so that I can see what it looks like. I have been looking in to doing this mode to my truck.
Old May 22, 2009 | 06:28 PM
  #64
TheFist's Avatar
TheFist
Originally Posted by Alpheus
The controller I got did not have a relay. Its just a open switch with a heat probe that closes when the temp you set is reached. As for the relays I used a Ford relay part #
FOAB 14B192-AA 8236-1 09 2R If you cant find any for cheap or free and can wait a couple days I will send you a couple for free. I pulled about 15 of these things when I was at Pick & Pull... If you want I can draw up the wiring diagram I used also. It simplifies the wiring...
I would really like a copy of that wiring diagram, if you don't mind.
Old May 22, 2009 | 08:32 PM
  #65
lxman1's Avatar
lxman1
Site Moderator
It looks like these http://cgi.ebay.com/ebaymotors/MUSTA...spagenameZWDVW
Old May 23, 2009 | 02:40 PM
  #66
Off_Road_Teacher
I do have some pics but you can't really see the fan that well because it is inside of the stock shroud. If you want pics of the brackets or anything like that let me know and I will send them to you.
Old May 27, 2009 | 12:37 PM
  #67
azlodaniel1
If you wouldn't mind I would like to see the Brackets.
Old May 27, 2009 | 05:57 PM
  #68
Off_Road_Teacher
Here are a couple of pics of the brackets that I made. They are made out of the material used for hanging a garage door opener. I cut it to length then bent it into u-shapes that go over the radiator and down to the e-fan shroud. Since the material has holes already in it the brackets are very easy to bolt up to the existing holes in the radiator.
