HELP with spindle lift
Hey all, I currently have a 2.5"coil spacer on my 07 2wd 1500...it kinda degraded the ride quality a bit when hitting bumps and turning sharply..I had new shocks put in, but it just doesn't seem the same...I was looking into a 4" spindle lift...but I am clueless when it comes to anything like this..I have heard both good and bad things about them, also heard you need new wheels when doing a spindle lift, OEM ones wont work...any insight would be appreciated...
Ive got a 2WD 04 1500 with a 2'' coil lift and 3'' spindle lift and you will not need new tires unless you think your old tires will look too small once you lift the truck. That would be the only reason you would need them. I have no complaints about mine though. IDK about a 4'' spindle lift but I have seen plenty of 3'' lifts.
Oh, you WILL need an alignment done to the truck after putting new spindles on
Trending Topics
spindle lift is the way to go for 2wd. it keeps all your front end components at the stock angles, doesnt degrade your ride quality. it just makes your wheel sit 3 inches lower in the spindle. you will need either new rims or some wheel spacers as the oem wheels dont have the right amount of backspacing. i think the oem wheels have something like 5" of backspacing, and the spindles need 4.5 or less i believe.
