Best MPH for gas milage
Old Mar 24, 2005 | 07:15 PM
bign1976's Avatar
bign1976
Default Best MPH for gas milage
Leaving for Tennessee in a little bit, just wondering what the MPH to travel at for the best gas milage???? First trip in new truck.... anyone???? anyone?????
Old Mar 24, 2005 | 07:43 PM
DonG's Avatar
DonG
Default RE: Best MPH for gas milage
Best I've gotten was just over 18 on a 200 mile trip @ 60. Really begins to suck the gas over 70. I get about 2mpg better at 65 than I do at 75, but I rarely see it since I usually set the cruse at 75 on the interstate.
Old Mar 24, 2005 | 11:32 PM
moparturd's Avatar
moparturd
I always sacrifice by driving 5 MPH over the limit. My HWY MPH is just over 20 MPG, with a best of 22.1 MPG.
Old Mar 25, 2005 | 12:05 AM
ramfan5.9's Avatar
ramfan5.9
yea prolly under 70, cause wind resistance makes you use more power to go that fast which takes more gas
Old Mar 25, 2005 | 12:20 AM
sig's Avatar
sig
dont be cheap!!!go fast[:@][:@]
Old Mar 25, 2005 | 12:33 AM
04hemiboy's Avatar
04hemiboy
30 mpg if you use MEXICAN OVERDRIVE
Old Mar 25, 2005 | 07:54 PM
locked up's Avatar
locked up
1MPH
Old Mar 26, 2005 | 12:29 AM
magnethead's Avatar
magnethead
well if memory serves, you use the least gas at the torque peak, even over idle. now assuming you have a HEMI (which only comes with the 545-RE).....
Torque peak is 375 @ 4200 RPM according to the dyno sheet ( http://www.hostpicsfree.info/show.ph...emidyno947.jpg )
Stock tires: 30"
545 RFE: 3.00, 1.67 upshift/1.50 kickdown(auto selects proper 2nd gear), 1.00, 0.75, 0.67
First Gear: 3.00:1, 4200 & 3.00:1 & 3.92 & 30" = 32 MPH
Second Gear (kickup): 1.67, 4200 & 1.67 & 3.92 & 30" = 57 MPH
Second Gear (kickdown): 1.50, 4200 & 1.50 & 3.92 & 30" = 64 MPH
Third Gear: 1.00, 4200 & 1.00 & 3.92 & 30" = 95 MPH
Fourth Gear: 0.75, 4200 & 0.75 & 3.92 & 30" = 127 MPH
Fifth Gear: 0.67, 4200 & 0.67 & 3.92 & 30" = 142 MPH
Now, since you can't shift it that way (and if you could it wouldn't be safe for the tranny...why the torque peak is that high who knows), I'd say 55 is the next best bet.
Old Mar 26, 2005 | 03:18 PM
vipersforsale's Avatar
vipersforsale
I cant drive 55!!!
I drove to Missouri last week and if I had driven 55 I would have been run over by even the little ole lady's. I set mine on 70 and still get 19+, do what you must but just get there without making too many enemies(like you would by going 55!).
Old Mar 29, 2005 | 01:10 PM
bign1976's Avatar
bign1976
Well Im back and went about 75-80 and got about 16.9- 17 mpg.
