MPG difference with tonneua cover
I watched a TV show called "Mythbusters" and they did some experements. This is what I remember:
Topper/Tonneau cover/open bed with tail gate up....Pretty much the same wind resistance. Not a noticable mileage difference.
Open bed with the tailgate down...More wind resistance and lowered the MPG.
The reason the open bed with tail gate down was worse than the others is because the wind resistance pulls on the outside and inside of the bed. If you have the tailgate up, there is an "air bubble" that does not have as much resistance on the passing air as the inside of the truck. You can witness the air bubble in the back if you have loose leaves or something back there. The leaves usually swirl around, but don't take off right away. I had a pop can float in the back of my truck for a good 20 seconds once at about 55 MPH.
Trending Topics
