Am i taking to much power from the alt?
Old 10-06-2009, 05:56 PM
dunerider650's Avatar
dunerider650
dunerider650 is offline
Default Am i taking to much power from the alt?
Well....my lights dim pretty bad sometimes heres what i got
1.) 4 - 100watt lights behind the grill
2.)2 - 10 inch woofers only powered by a 800watt amp
When the bass hits holy hell do all my lights go dim...am i drawing to much from the alt?? could this problem be fixed by adding a second battery??? im wanting to add more lights to the truck thats why im asking.
Old 10-06-2009, 06:31 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
I would invest in a good capacitor from a reputable stereo shop.
Old 10-06-2009, 07:19 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
That is 85 amps, not allowing for wasted heat from the amp, which likely isn't 800 watts, BTW. Quite a chunk for a 136ah alternator. The capacitor seems a good idea.
Old 10-06-2009, 07:21 PM
nim81's Avatar
nim81
nim81 is offline
ive got 4 hellas and a 1600 watt amp and i havnt had any problems with everything on
Old 10-06-2009, 07:42 PM
jdfisher's Avatar
jdfisher
jdfisher is offline
like someone else sound get a good 2 farad capicitor, it will help with the lights dimming when your amp is driving at low frequency.
Old 10-06-2009, 08:04 PM
Freakinkeith806's Avatar
Freakinkeith806
Freakinkeith806 is offline
Yeah, go for a cap! lol, I put a 2 farad cap on mine and my battery doesn't crap out anymore, and my lights do not dim.
Old 10-06-2009, 10:18 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Caps are band aids, not fixes. I would at least do a Big 3 upgrade on your power and ground wires. Then look at maybe a newer and/or bigger battery or alt.
Old 10-06-2009, 11:56 PM
kx250frider617's Avatar
kx250frider617
kx250frider617 is offline
http://www.odysseybatteries.com/
Get a AMG battery like these. They are around 1/2 the size and put out twice the power and are 100x better than any other battery such as a optima or whatever. I have been wanting one for awhile but are expensive.
Old 10-07-2009, 07:34 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
This is why you only see them in truck in mags with guys who either are rich or sponsored.....LOL
Honestly though, not many people can or will buy A battery like that. Again, I had no issues in my truck with my one battery and OEM wiring. I was running Everything I have now minus my winch and I only added my second battery for that but even the winch never gets used.....yet.
Old 10-07-2009, 07:45 AM
snidehockey's Avatar
snidehockey
snidehockey is offline
Make sure your Amp isn't hooked up at 0 ohm. I screwed up my math and had it at a 0 load and it would dim the lights etc when it was hitting. I eventually killed the amp, and once I took everything apart realized it was that. I got a new amp and hooked the subs up properly at 2ohm...now no more dimming.
Quick Reply: Am i taking to much power from the alt?
