Long Tubes Installed! (Now with a Video)
Old Jan 18, 2010 | 07:35 AM
  #41
jbrowder's Avatar
jbrowder
Originally Posted by Off_Road_Teacher
They are Pacesetter headers, magnaflow high flow cats and pacesetter piping after the cats. The one header on the passenger side did not fit, not sure if my truck is different or the header was wrong or what, but I had to cut it up a little to get it to fit.
Why didnt it fit? Was it hitting something? Has anyone else had this issue? I was looking at getting the pacesetters in the near future.
Old Jan 18, 2010 | 07:37 AM
  #42
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it would stop raining I could set up the camera on the front porch and do a couple drive bys. Tried to get the wife to hold the camera for me but she wants no part of standing in the rain while I drive around
When i did my drive by vid on youtube, my wife stood on the side of the road for me and it was 27* outside, she pbviously wasnt as excited about it as i was..........
Old Jan 18, 2010 | 07:47 AM
  #43
HammerZ71's Avatar
HammerZ71
The only issue I can remember running into was one of the bolt holes on the flange not lining up and having to drill it out a bit to fit. I think it was on the passenger side. Was in the spring of 06 (damn time flies) but I believe that was the side...
Old Jan 18, 2010 | 07:55 AM
  #44
Off_Road_Teacher's Avatar
Off_Road_Teacher
Good memory man, that is exactly what it was. The bolt hole at the very front of the flange does not line up and no matter how many ways I tried to get it to line up the hole in the flange was just too far off to get it to fit. So I took it and cut a slot in the flange just like was on the stocker. Once I did that it went on with no problem.
Old Jan 18, 2010 | 09:06 AM
  #45
weedahoe's Avatar
weedahoe
Hall of Fame Member
Good to know info. THX
Old Jan 18, 2010 | 12:48 PM
  #46
Brokenpath's Avatar
Brokenpath
Teach have you considered a resonator?
When I looked under my truck it seemed like NOTHING would fit in there except for the most SQUINCHED design. can you post a picture of the headers in the truck?
Also I know what you guys mean by how ****ty the old exhaust manifold is it's pinched in the middle and a whole mess of other things. Makes me feel like the catback piping i did is basically a waste of money. Made me make headers next in line for mods, I want my ram to breathe!
Old Jan 18, 2010 | 05:22 PM
  #47
Off_Road_Teacher
I can get a pic for you when I crawl back under there. Why am I going back under there already you ask, threw a code today P0157, downstream sensor on the passenger side . Not sure if it is a bad sensor or if I messed up the wiring when I was splicing it. Guess I am going to have to get under there and take a look at my wiring.
Old Jan 18, 2010 | 08:57 PM
  #48
Brokenpath's Avatar
Brokenpath
Cool, thanks.
Is it safe to run your car without an oxygen sensor? (Just googled downstream sensor)
My car before this one was a 72 nova, so it was basically the 2 screws in the front of the carb to adjust the mixture.
It's scary knowing that the computer controlls the amount of fuel that goes into your vehicle.
Are there ways too pump more fuel/air into the vehicle without really expensive modifications?
Old Jan 18, 2010 | 09:49 PM
  #49
Off_Road_Teacher
It still runs fine with the rear O2 sensor problem. All that one does is monitor the efficiency of the cats.
Old Jan 18, 2010 | 10:33 PM
  #50
truckin151's Avatar
truckin151
That front header bolt goes to the EGR port, I did not put that one on and there are no leaks. The sensor is probably because of the high flows not the sensor or wiring itsself, I have heard problems with the highflow cats because of that.
