leveling spacer question
Old 02-11-2010, 07:38 PM
meen green machine's Avatar
meen green machine
meen green machine is offline
Default leveling spacer question
ok si i got just got some leveling kit spacers for my truck there 2 inches tall. am i going to need an alignment for sure after i install them. i had a friend who had a 4 wheel frive dodge and he got the spacers tghat into the top and he didnt need them
Old 02-11-2010, 07:39 PM
meen green machine
correction: he didnt need an alignemnt
Old 02-11-2010, 07:41 PM
rtmtrrdr's Avatar
rtmtrrdr
rtmtrrdr is offline
If your is 2wd i would say yes.I just put thoose in my 2wd and i positvely absolutely 100% needed an aighnment
Old 02-11-2010, 08:01 PM
meen green machine
do you know about how much an alightment runs?
and it says to install them under the coil but i have heard some who put them on top would this help any?
Old 02-11-2010, 08:03 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
It doesn't matter if it's 2wd or 4wd. The spacer changes the whole geometry of the front end and you WILL need and alignment. Just figure that into your cost. Did you buy your shocks too? You'll probably need those a little longer.
Old 02-11-2010, 08:04 PM
cwboyjohnny24
All the coil spacers I've ever seen go on the top of the spring my friend, not the bottom. The bottom has to sit in an indention in the spring bucket.
Old 02-11-2010, 08:06 PM
meen green machine
no i didnt get shocks. the seller said that he has installed them on many trucks and everybody ive heard witht hem said they worked fine. the seller said on most of the trucks he put them on they didnt need an alignment, which im highly doubting.
Old 02-11-2010, 08:09 PM
Bluesmanjesse's Avatar
Bluesmanjesse
Bluesmanjesse is offline
Mine went on top,2",needed alignment,make sure the alignment shop knows that you added the spacers. Prices vary for probably $40 -$100. They had to use special alignment straps on mine because the wheels were too deep for thier normal equipment. I paid $80 roughly,alot cheaper than new tires!
Old 02-11-2010, 08:17 PM
cwboyjohnny24
On model trucks before '06 most trucks do a lot better with longer shocks. The stock shocks on mine actually held the upper and lower control arms together and didn't allow for travel since they were topped out and I only went up 2". Just a thought. You need an alignment and if he told you you don't he may not know what he's talking about.
Old 02-11-2010, 08:32 PM
sharkhunter10's Avatar
sharkhunter10
sharkhunter10 is offline
i needed an alignment after mine! I would and it dosnt hurt to get one period!
Quick Reply: leveling spacer question
