Catastrophic Trans Failure.
Old Feb 13, 2010 | 06:20 PM
  #21
BEAR's Avatar
BEAR
MAN! Sorry to hear all this John...Hope it all works out for the good for you.
Old Feb 13, 2010 | 07:47 PM
  #22
OlDirtyJohn's Avatar
OlDirtyJohn
Originally Posted by truckin151
What were you doing when it blew? did it thow a code first? were you watching the trans temp or even install a trans temp gauge?
when it happened i was coasting along at 55mph on base. the temp was fine until then, and it didnt throw any codes until then. everything was fine until all of a sudden, trans went crazy, lost gears, temp soared and threw codes, like all at once.
Old Feb 13, 2010 | 08:44 PM
  #23
RedTruck-VA's Avatar
RedTruck-VA
"coasting along at 55mph on base" That just doesn't sound right, Usually they give up while at high rpm going into second gear. I might want to look closely at the TC and pump for initial cause of failure.
Old Feb 13, 2010 | 08:55 PM
  #24
Horseapples's Avatar
Horseapples
i had a 727 grenade like that once, the converter snout was not machined deep enough where it engaged the trans pump, the snout forced the pump to ride against the thrust plate, and eventually the metal shavings destroyed the planitarys, then BOOB! goo all over the drag strip!
Old Feb 13, 2010 | 11:23 PM
  #25
lxman1's Avatar
lxman1
Site Moderator
You got BOOB goo all over the drag strip?
I agree with Horseapples. Probably why they are so eager to replace your converter and even pick up the old one!!
Old Feb 14, 2010 | 12:21 AM
  #26
truckin151's Avatar
truckin151
Yeah but if the TC had something off or wrong I would think it would have been running hotter than normal or had some idication that it was going bad....
Old Feb 14, 2010 | 12:44 AM
  #27
OlDirtyJohn
no new update on the trans, but just got back from the ER. took like 4 hours! as expected last digit of my ring finger was mildly crushed. fractured in a few locations to be exact. nothing too serious, no surgery or anything needed. they just drained the excess fluid, put it in a small cast, gave me some vicodin, and sent me on my way.
also, im seriously considering getting the sharadon stage II trans and stage II valve body. i can get it from moes with no core charge, free shipping, and no sales tax. although i did some research on it over on DT, and that just pissed me off more than anything. now i know why i NEVER go to that site.
so if anyone has any insight on the sharadon tranny, im all ears. otherwise ill probably just grab a reman from somewhere and call it a day.
Old Feb 14, 2010 | 04:46 AM
  #28
abarmby's Avatar
abarmby
Yeah, I ain't about to make an assumption and say it was the installation of the TC or the shift kit, but the fact that so soon after the install your tranny blew up raises a red flag. I would bet the ranch that if you had not done a thing to the tranny it would still be working fine.
Probably was a situation where the new components pused a ? transmission over the edge, but I don't think you'll ever know.
Side note, as someone who was a catcher for about a dozen years including a couple stints in the lowly minors, you got you a busted finger. I've broken every one of mine at one time or another, and my right wrist twice and left wrist once. Only parts I've never broken were either of my thumbs...
WOW Hammer.....I bet your hands and wrists ache like a SOB in winter with all those old breaks and stuff?
AS for the Transmission problems OlDirtyJohn, I feel for you bro'.
It's not just that the transmission blew, although that's bad enough, it's also a confidence thing as well.
Was it installed right....was that part in the shift kit installed correctly....was the torque converter OK???? stuff like that.
All that second guessing stuff screws with your head and makes everything worse. So much so, that your now considering a "turn key" solution to your problem, by buying a complete modded tranny costing probably a lot more $'s.
I've been there with an engine I rebuilt years ago.
Anyhow, good luck and post up what you finally do.
Al.
Old Feb 14, 2010 | 06:40 AM
  #29
Horseapples
oops! LOL thats what i get for typing while intoxicated!
