Please Help~! Engine knock after oil change
Old Mar 22, 2010 | 04:00 AM
  #31
ballmart's Avatar
ballmart
Switched to synthetic at 16k miles. Got the tick, was worried but warranty will take care of me. I'm now at like 31k, mobil1 synthetic with mobil 1 filter 201, ticks sometimes but not always.
When I looked into the mobil 1 filter, it had some type of glue at the bottom. Should I be worried? and did you have it too?
But anyways,- probably hemi tick, if not check oil level and if the filters properly installed.
Old Mar 24, 2010 | 01:32 AM
  #32
IowaHemi1's Avatar
IowaHemi1
Post Synthetic oil and hemi tick
Just curious how many people got the hemi tick after they went to synthetic oil? I'm almost positive i did not have it when i ran conventional oil. I only put 3,000 miles a year on truck,so i figured i would use synthetic and just change oil once a year. Might have to go back to conventional and see if tick goes away. This link is helpful for info on mixing synthetic and conventional oil. http://www.valvoline.com/car-care/motor-oil-myths/
Old Mar 24, 2010 | 02:32 AM
  #33
RedTruck-VA's Avatar
RedTruck-VA
Default tick
I bought my truck new and started using Mobil 1 after the initial 5000 miles. I have had the tick on occassion but it quickly goes away. My truck has been sitting for the last 6 months and when I went to start it today I fully expected it to have the tick. It didn't, fired up as if I had just driven yesterday. It took the tires a few miles to smooth out. But "No tick". Has anyone determined what extactly is the tick? Lifter?
