DIY Tranny Line Pressure Booster
Old Apr 9, 2010 | 10:41 AM
  #71
RubberFrog's Avatar
RubberFrog
sonnex ftw!
Old Apr 9, 2010 | 10:43 AM
  #72
abarmby's Avatar
abarmby
Originally Posted by RubberFrog
sonnex ftw!
Huh ??????
Al.
Old Apr 9, 2010 | 10:56 AM
  #73
hemiguy0302's Avatar
hemiguy0302
Do you have the sonnex frog? I looked at it seems to be a nice looking unit.
Old Apr 9, 2010 | 10:58 AM
  #74
RubberFrog's Avatar
RubberFrog
soon!
Old Apr 9, 2010 | 11:02 AM
  #75
AF_HEMI's Avatar
AF_HEMI
if its good enough for frog its good enough for me!
Old Apr 9, 2010 | 11:04 AM
  #76
hemiguy0302
Thats what I'm thinking. Frog when you get it be sure to post results. If not I should have one this summer to report about.
Old Apr 9, 2010 | 11:09 AM
  #77
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://www.sonnax.com/announcements/44957-LB1_LB2.pdf
Part number 44957-LB1 (68RFE) has 10-15 psi increase, and 44957-LB2 (45/545RFE) has 15-30 psi increase. Higher line pressure increases clutch holding power and torque capacity but with these transmissions, the increase has a limited effect on shift feel. Changes in shift feel ill be noticed mostly under aggressive driving or loaded conditions.
Old Apr 9, 2010 | 11:16 AM
  #78
RubberFrog's Avatar
RubberFrog
It's basically a plug and play resistor. I'm not a fan of hacking up the wiring harness that close to the ground.
Old Apr 9, 2010 | 11:21 AM
  #79
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^^ to go along with RFs response
http://www.dodge talk.com/forums/showthread.php?t=292942
Old Apr 9, 2010 | 11:25 AM
  #80
AF_HEMI's Avatar
AF_HEMI
this is exactly what i want. noticeably firmer shifts under hard throttle, but more stock like in granny-driving. I'll be gettin one soon
