3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
If you go to a SCT Tuner you should be alright to compensate for the new motors parameters and you will be able to disable to the MDS. I would contact hemifever because he has tuned a couple hemi motors that have been dropped into 4.7 using the original wiring. I don't know how you are going to wire the dual spark plugs tho. Thats gonna be a deal breaker.
Yeah, guys I am going from a 04 Dodge 1500 to a 07 5.7 hemi. The truck runs great for 5 minutes then dumps fuel heavily and misses badly. Dont have any codes but O 2 sensor naturally with all that fuel.
I dont want to press 1 either. Thanks for your help. I guess unless anyone has a better idea I will pull this 07 and look for an 04. Dam, I wanted to keep this new hemi in for awhile.
