just changed my rear diff! so easy a caveman could do it!
Old Jul 22, 2010 | 01:57 PM
  #21
Bluesmanjesse's Avatar
Bluesmanjesse
Originally Posted by RubberFrog
gear oil smells like horse ****
Roflmao..... As an industrial Maintenence tech I can confirm the level of stank of gear oil,ecspecially gear oil that's been in there waaaayy too long. I changed the oil in a gearbox on a Blanchard machine from the 50's and I think it was the original oil,it was like death when i craked the drain open on that thing!!
Old Jul 22, 2010 | 02:20 PM
  #22
Gasturbine's Avatar
Gasturbine
Originally Posted by OlDirtyJohn
he changed his differential FLUID, not the whole unit.
Heh heh, thats not what he said, and I thought he changed the diff too. I was about to jump in a scream about gear lash, pinion pre-load, and gear tooth contacts, but all is good now.
-Chris
Old Jul 22, 2010 | 04:17 PM
  #23
rocket23's Avatar
rocket23
I like the blackened bolt look against the red pan . For me it's an easy look.
Old Jul 22, 2010 | 05:07 PM
  #24
lxman1's Avatar
lxman1
Site Moderator
Well, the red cover matches the shock boots I guess.
Old Jul 22, 2010 | 07:33 PM
  #25
JOHNSN10's Avatar
JOHNSN10
Cant have everything black
Old Jul 22, 2010 | 07:41 PM
  #26
rocket23's Avatar
rocket23
you a member or the btc yet?? ^^^^
Old Jul 22, 2010 | 09:36 PM
  #27
Yeags777's Avatar
Yeags777
if you have that much black, you might as well black that cover too. just my $.02
Old Jul 22, 2010 | 09:43 PM
  #28
jake7's Avatar
jake7
but a black cover wont stick out at all...it'll just look "clean"...
John you should do the calipers the same color now too...that way a few things will match up and flow together...even though you'll really only see calipers while driving at higher speeds.
Old Jul 23, 2010 | 09:31 AM
  #29
HKS's Avatar
HKS
Default Ring Gear 3.92
Hello,
You mention C clips, that means you have a 3.92 diff. Here is what happened to my new 2010 Ram at 2000 miles with the 3.92 differential.
How hard is it to replace the ring gear?
My 3.92 locking differential started making whining noises between 45 and 55 mph. Dealer installed gear kit-ring and pinion, bearings and seals. Mechanic found zero gear backlash and found pinion had no bearing preload.
Sounds like it was made on a Monday or Friday. I am loosing faith in American workmanship but I love my beautiful 1500 SLT Crew Cab, 5.7 Hemi Bighorn with the Ramboxes.
I hope the local machanic did a better job than the one with the Unioin Label.
HKS
P.S I found some pretty scarry posts on other websites about the 3.92 diff falling apart and drive shafts falling off.
P.S.2 The work order stated "Replace rear pinion and bearings and refill fluids and road test" This means they did not put in the ring gear which was part of the kit.
The machanic's notes said "Replaced ring gear and pinion etc." which is a lot more work than just replacing the pinion"
Originally Posted by JOHNSN10
ive been putting this off for awhile now but today i finally changed the rear diff myself. i was worried that it would be harder than it was but it was so easy. i took the cover off cleaned it all out and found no metal chunks on the magnet but i did find a layer of black sludge covering the magnet which probably prevented it from collecting the metal shavings. my ram is blacked out but i wanted to add a touch of color so i painted the cover red with caliper paint. i used the permatex 1 minute gasket maker and as soon as i bolted the cover back on i added fluid and had no leaks i did not use a torque wrench - all u need is hand tight then 1/2 a turn till its snug with a wrench. i used royal purple too and its only $11.99 a bottle on amazon.com compared to $19.99 a bottle at local stores. my "c" clips looked good so i left them alone. here r some pics.
Old Jul 23, 2010 | 09:59 AM
  #30
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by HKS
Hello,
....The machanic's notes said "Replaced ring gear and pinion etc." which is a lot more work than just replacing the pinion"
First of all C-clips are what hold the axles in place. The clutchpack reainer clips are what hold the clutch packs in place. 2 diff clips. I know most people call the ratiner clips "c-clips" but that's incorrect.
The retainer clips or as u say c-clips have nothing to do with 3:92 which is the gear ratio. it has to do whether or not you have a limited slip differential or an opne one(one-wheel peel).
In order to change the pinion gear which is the small gear all the way in the back, you must remove the ring gear which is the larger gear on the left. The only harder part to change the ring gear would be to remove the 10? bolts that hold it onto the LSD carrier. I'd be very surprised if the mechanic didn't change the ring gear along with the pinion gear as they are a matched machined set, although that would be very dealer like while being under warranty.
