Transmission Line Pressure Booster
Old Sep 26, 2010 | 01:43 PM
  #61
runvs's Avatar
runvs
ok....cool, well i already have the resistor on 1and 3 so i may try to add the 350ohm resistor on line 2 ifselft....inline.....what watt 350 ohm resistor did you use?
Old Sep 26, 2010 | 09:52 PM
  #62
rengnath's Avatar
rengnath
Has anyone successfully used this in conjunction with the Superchips Transmission Tuning with reduced torque managment to 10% or so? I would like to keep the TM reduced so my truck will pull through the shifts at WOT, but if this would firm up the shift even more and prevent slipping that would be awesome. I dont feel like destroying my transmissions since it already has 110k on it. I figure anything your Hemis can throw at the 545rfe, I should have no problems with my 4.7l. Thanks for any help.
Old Sep 26, 2010 | 10:59 PM
  #63
JonnyBlaze420's Avatar
JonnyBlaze420
Hello. Can someone make me one??? I'll paypal someone. I'll need installation instructions too. Also maybe a "power wire"... THANKS!
2003 Ram 1500 4x4 4.7l.
Old Sep 27, 2010 | 08:44 AM
  #64
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got a spare one I had made and a Power wire in my tool box. PM me.
Old Sep 30, 2010 | 12:45 PM
  #65
azlodaniel1's Avatar
azlodaniel1
I tested a 390ohm 1/2 watt resistor last night and it is way better then the 350 I built.
The shifts are faster and harder. I am very Pleased with the 390ohm on Line 2.
Attached it what I did to connect them to my truck. I used a 3 wire plug so that I can test the 2.2k and any others I want, really easy.
Old Sep 30, 2010 | 02:18 PM
  #66
OlDirtyJohn's Avatar
OlDirtyJohn
good job man! looks awesome. and doesnt it feel great to know that you saved yourself $40+ by doing it yourself?
Old Sep 30, 2010 | 03:22 PM
  #67
weedahoe's Avatar
weedahoe
Hall of Fame Member
Super nice pic and work there.
Old Sep 30, 2010 | 04:36 PM
  #68
rengnath's Avatar
rengnath
Would anyone advise against running the Superchips transmission tuning (Torque management @ 10%) while boosting line pressure?
Im thinking it would actually help with the reduced torque managment by preventing any slipping that occurs in the lowered TM ranges. I dont want to tear the transmission apart with this combo.
Old Sep 30, 2010 | 08:04 PM
  #69
OlDirtyJohn
i run it, havent had any problems at all. shifts nicely.
Old Sep 30, 2010 | 08:29 PM
  #70
rengnath's Avatar
rengnath
Thanks John. I would assume it would only help, since reducing torque managment really doesnt reduce wear on the tranny. I think Ill give this a try on my Dakota. What do you have your TM at with the line booster?
