Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Feb 14, 2013 | 03:54 PM
  #531
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you leave the headlights on, then turn the key off, the headlight will stay on. Thats normal and made to light your way visually to see where you would be walking.
You are correct about no DRLs only in the CAN and not the US
Please post a pic of your bixenon harness
Old Feb 18, 2013 | 06:04 AM
  #532
Mick0311's Avatar
Mick0311
Default Lost in the sauce
I ordered the 9007 Hi/Low setup from Hidextra with the relay harness. I also ordered 2 50w 6 ohm resistors.
I'm trying to clarify what plugs go where.
The relay (square, not rectangular box) gets powered from the battery (red and ground wires). Constant draw? The relay has 2 male plugs to power the ballasts. Not sure where the 3rd plug goes, it's a 2 wire female plug.
2004 Ram
Old Feb 18, 2013 | 09:16 AM
  #533
weedahoe's Avatar
weedahoe
Hall of Fame Member
2004 Ram
I am assuming you mean you bought the HID lo/Halogen hi because the square relay is only for xenon kits and not bixenon.
As for the plug, post a picture of it
Old Feb 18, 2013 | 01:57 PM
  #534
Mick0311's Avatar
Mick0311
Here is a pic of how I think it all connects.
The circle is the plug in question.
The oem plug will connect to the blue.
I'm waiting on new plugs to make pnp resistors.
The relay is what was sent with the HID kit.
Attached Thumbnails Got *HID* Problems? Check in here...-20130218_103226.jpg
Old Feb 18, 2013 | 06:48 PM
  #535
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, thats the thing about these harness's, each plug has only one place to go.
I have pre-made HID PnP resistors BTW. Too bad you didnt ask
Old Feb 18, 2013 | 08:13 PM
  #536
Mick0311's Avatar
Mick0311
Back towards the beginning of this thread you said don't ask me to make you one and posted a link to pre made ones. LOL
Old Feb 18, 2013 | 09:54 PM
  #537
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, this thread was also started back in 2010....lol
Old Feb 19, 2013 | 10:47 PM
  #538
bsharp74653's Avatar
bsharp74653
Hey guys and gals.. Obviously I'm new to the forum... But I'm purchasing a 03 Dodge Ram Quad Cab Thunder Road Edition from a buddy. Now I'm new to the dodge ownership. I've always owned chevy in the past. But from everything i've read and from what i read in this post theres issues with the HID's and resistors being needed.. Basically I'm looking at ordering some HID's for this dodge.. It'll be one of the first things I do. So if someone could please point me in the right direction of what I need... Previously I've always went through DDMtuning for all of my HID needs but if there is somewhere better please let me know...
Also here is the vehicle im getting
Attached Thumbnails Got *HID* Problems? Check in here...-259880_556059517753017_698913002_n.jpg
Old Feb 19, 2013 | 11:29 PM
  #539
weedahoe's Avatar
weedahoe
Hall of Fame Member
DDMtuning is fine. You just need to add load resistors with them to trick the PCM
Old Feb 20, 2013 | 05:35 AM
  #540
bsharp74653
Is there a specific set I should get?
http://www.ebay.com/itm/290830825687...84.m1423.l2649
That work?
Okay so heres what I'm thinking
12000k 55W for the headlights hi/lo
10000k 35w for the Fog Lights
Now for the fogs do I also need these load resistors? Also I'm ordering 2 battery wiring harness one for each kit correct?
