Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 6, 2014 | 01:18 PM
  #761
RamRod37's Avatar
RamRod37
Originally Posted by ffsag
Exactly what I did.
Im out of idea's I cant figure out whats going on with yours that's weird
Old Aug 6, 2014 | 03:33 PM
  #762
Izero's Avatar
Izero
How about we have him diagram or list out all of his connections?
List out where each of your connections are coming from and going to... then we can start narrowing down some potential causes and solutions.
Old Aug 6, 2014 | 04:14 PM
  #763
RamRod37's Avatar
RamRod37
yeah cause it still sounds like the resistors are wired in wrong Locations
Old Aug 6, 2014 | 11:04 PM
  #764
ffsag's Avatar
ffsag
Ok i think i did it correctly. I watched a lot of pics and vidz to make sure that im ok. I connect 1 side of the resistor to the low beam and the other side to the ground on the oem wiring. I have sold them in place and added heatshrink. I start my truck and touch the resistor and they come hot, sk i think they work. Maybe i missed something. Those hid gonna make me crazy...
Old Aug 6, 2014 | 11:22 PM
  #765
RamRod37's Avatar
RamRod37
Ok On Your OEM Wiring Harness At The Headlight Connector the ground is the center wire Should be Black W/Blue Stripe on left side headlight connector is that the wire that one end of resistor is tied too?
I ask this because diagram you previously loaded the link is not loading to see what you looked at
Old Aug 8, 2014 | 09:40 AM
  #766
Izero's Avatar
Izero
You might be over loading the ground by grounding it back into the OEM harness....
Try grounding the load resistors to the chassis and see if that works out a little better....?
Old Aug 16, 2014 | 02:05 AM
  #767
FreezLe223's Avatar
FreezLe223
okay guys, i just got my projectors in for my 2006 dodge. after installing h1 hid kit for only lows. i found out i have a flickering problem maybe every 30 secs or so. what do i need to fix this? my fog light hids work perfect no relay harness at all. My low beam h1 hids in my projectors are on a relay harness. i have 2 resistors 50w *8 wondering if these need to be used to stop flickering or not? please help here is some pics.
(my resistors)
(using only red & blue plugs for my Hids)
Old Aug 16, 2014 | 03:22 AM
  #768
RamRod37's Avatar
RamRod37
(my resistors)
Yes driving lights are not can bus and are already relayed through fuse panel but the headlight how ever are can bus and yes since you already have headlights on Relay you need to tie the resistors one between headlight ground and low beam !2v each wire from the one resistor one to the ground the other too low beam 12vdc+ do this on both headlight connectors this will eliminate the Flickering Issue your having now
Old Aug 16, 2014 | 08:26 AM
  #769
FreezLe223's Avatar
FreezLe223
where do i hook the resistors up at? i am using my oem plug on one side to trigger relay. Do i connect resistors to the same place when i tapped my running lights before the factory oem plug.
Old Aug 16, 2014 | 08:28 AM
  #770
FreezLe223's Avatar
FreezLe223
Also halogens was originally in the projectors i am not using the low beam wires anymore. i have spliced them and put my hids in. but i am wondering where do i install resistors like i said i am on a relay harness.
