Can you wire fogs to stay on with Highbeams for '05?!
Old 01-08-2011, 02:16 AM
A14Austin's Avatar
A14Austin
A14Austin is offline
Default Can you wire fogs to stay on with Highbeams for '05?!
I got an 05 rumble bee, i want to know if you can make it so the fog lights stay on with the highbeams on at the same time???
Old 01-08-2011, 03:02 AM
offroadjosh's Avatar
offroadjosh
offroadjosh is offline
Nope not possible at all sorry.. Jk man search on here and you will find it, believe there is a write up..
Old 01-08-2011, 06:33 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
https://dodgeforum.com/forum/3rd-gen...-beam-diy.html
of course, you can go to the dealer and try to talk them into setting your lights to the "international" settings which will do it the right way...
Old 01-08-2011, 04:23 PM
Geezir's Avatar
Geezir
Geezir is offline
While on the topic anybody heard of any issues with jumping the two relays? Frying electrical components? Popping fuses? etc....
I want to do this on my '05 but want to make sure it's not a risky fix.
Old 01-08-2011, 06:28 PM
HammerZ71's Avatar
HammerZ71
Nah, I ran mine thisaway for about three years and only undid it when I installed my off-road lights and wired that relay to the fog light relay to share the same switch. You're simply jumping the switch which carries about .3 amp.
I'm going to have a buddy of mine at a Jeep dealer change my settings to do it the right way though, as soon as I can get down to see him.
I'd like to be able to do fogs, 130 watt off-roads and highs at the same time off-road.
The above would still work, but I'm not comfortable stuffing all those wires down one single relay pin...
Old 01-08-2011, 07:50 PM
HouseApe's Avatar
HouseApe
HouseApe is offline
I would rather see you jump pin 86 to 86 as this is the coil ground. 87 to 87 is the load side of the relay. Your fogs will be on anytime the park lamps are on.
Old 01-09-2011, 07:33 AM
R-TICAT's Avatar
R-TICAT
R-TICAT is offline
Default Tell me more
I did the jumper yesterday but, I would rather the fogs not be on anytime the parking lights are...
Is this possible? Is that what you're saying about jumping 86-86?
Old 01-09-2011, 08:51 AM
rideon20z's Avatar
rideon20z
rideon20z is offline
i did the jumper from Hammers DIY and mine are on all the time when the parking lights are on know matter if i pull the button or not , so House ape how do i know what number 86 and 86 are ?? i must of done 87 to 87 if there on all the time? where are the two 86?
Old 01-09-2011, 11:02 AM
HouseApe's Avatar
HouseApe
HouseApe is offline
it is not possable to stop the fogs from coming on with the Parks even if you use pin 86. The pins are numbered on the underside of the relay.
Old 01-09-2011, 11:36 AM
rideon20z's Avatar
rideon20z
ok cool i thought you were saying it was but thats cool either way . your just saying it mught be safer to use the 86 pins
Quick Reply: Can you wire fogs to stay on with Highbeams for '05?!
