Bad wheel bearing?
Old Mar 22, 2011 | 09:21 AM
1987notchback's Avatar
1987notchback
Default Bad wheel bearing?
in the past few days i have been hearing a high pitched grinding sound from the right rear of my truck it does it once in awhile for short periods of time. it is a different noise than the rearend. could it be my wheel bearing? i hope not but can not think of what else it would be? i recently did new u-joints but greased them well. what do u guys think? thanks mike
Old Mar 24, 2011 | 07:39 PM
1987notchback
anyone had any experience with this or actually replaced a rear wheel bearing? thanks mike
Old Mar 24, 2011 | 08:46 PM
lxman1's Avatar
lxman1
Site Moderator
Either an axle bearing or carrier bearing in the rearend.
Old Mar 24, 2011 | 09:40 PM
freestyledude's Avatar
freestyledude
Sounds like pinion bearing, but I'd drop the diff cover pronto and look for broken clips
Old Mar 25, 2011 | 06:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My first thought it the pinion bearing also. But you can download the 05 Srvc Man from the links in my signature
Old Mar 26, 2011 | 06:30 AM
1987notchback
ok thanks guys i am planning on changing the diff oil asap and will do an inspection while it is open. thanks mike
Old Mar 26, 2011 | 08:28 AM
dirtydog's Avatar
dirtydog
Moderate User
My first guess would be the center carrier bearing for your driveshaft. Go grab and try to see if any or how much movement there is.
Maybe the noise changed with diff weights in the bed???
Old Mar 26, 2011 | 09:15 AM
luvmyhemi65's Avatar
luvmyhemi65
I replaced both front wheel bearings in December. At first I thought that it was in the Diff too. But the problem ended up being in the front end.
SM
2004 Ram Quad Cab
Old Mar 31, 2011 | 07:06 AM
1987notchback
it generally makes more noise with more weight. in regular driving it comes and goes only does it once in awhile. thanks mike
Old Mar 31, 2011 | 07:44 PM
lxman1's Avatar
lxman1
Site Moderator
Just had my left front hub replaced yesterday. They have both now failed in 45k miles. 2wd and hwy miles. ( same hub/bearing as a 4x4)
Sounded like my rearend too but i could barely feel it in the steering wheel.
