flashing 4x4 indicator lites
Old Sep 30, 2012 | 07:35 PM
ramman666's Avatar
ramman666
Default flashing 4x4 indicator lites
anyone have a problem with flashing indicator lite for the 4x4 on a 2006 ram 3500 5.9
Old Sep 30, 2012 | 10:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 3rd Gen Ram section.
Old Oct 1, 2012 | 11:16 AM
drewactual's Avatar
drewactual
this actually should have gone to the cummins section...
but...
a flashing indicator light isn't a good thing.. it generally means something is in peril.. that said, the little switch that mounts in the top of the transfer case that's sole function is to indicate the position of the transfer case is a known weak link on these rigs.. and could be the issue.. except, I've never heard of them causing flashing, jsut inaccurate readings..
does it flash rhythmically or not? if it flashes all helter skelter, I'd figure that switch is your issue..
Old Oct 1, 2012 | 12:05 PM
willdikem66's Avatar
willdikem66
I was going to say if it flashes randomly and 4x4 wont engage its your switch
Old Oct 1, 2012 | 01:22 PM
ramman666's Avatar
ramman666
ok well thanks for those comments
Old Oct 1, 2012 | 03:21 PM
boopadoopa's Avatar
boopadoopa
https://dodgeforum.com/forum/3rd-gen...t-came-on.html
I have asked this question in the past with no help... I just let it flash and now it quit. Ill find out this winter if its an issue
Old Oct 1, 2012 | 04:10 PM
willdikem66
Are yall not checking to see if its even going into 4x4?
I buy all my trucks with 4wd as an option but i check atleast once a month that 2wd/4wdhi/4wdlo all work? Thats the point of having it is for it to work...
Old Oct 2, 2012 | 09:33 AM
boopadoopa's Avatar
boopadoopa
yes I check it often and its does work. I just keep getting random flashing 4x4 light in dash when going down the road... and the truck acts different while its flashing. And the **** is in the off position.
Old Oct 2, 2012 | 09:44 AM
drewactual's Avatar
drewactual
tell me how it acts differently?
is the flashing rhythmic?
Old Oct 2, 2012 | 10:52 AM
willdikem66
Well atleast we know it works. some one had a similar problem with no 4x4 light, but it would engage the 4x4 they replaced the switch
