Please help!!!! Driving me nuts
Old Oct 24, 2012 | 12:29 PM
  #31
DodgeCares's Avatar
DodgeCares
Originally Posted by Wilson01960196
Ill check the harness..would tye ac line somehow mept tge harness?
I am not really sure what you are asking but I think the idea to this case is that a short could occur at this location and cause a problem throughout the system so it is something to check. In order for there to be a case on this it must have happen to someone and that was the confirmed fix. So I figure since nothing else has worked to this point I may as well mention it and just maybe it could possibly help you.
Old Oct 24, 2012 | 12:36 PM
  #32
Wilson01960196's Avatar
Wilson01960196
I glanced at it on break and didnt see any wires sitting on the ac line..is there any other grounds in the engine bay i should check?
Old Oct 24, 2012 | 12:50 PM
  #33
DodgeCares's Avatar
DodgeCares
That is the only one I found anything on. Hopefully someone else has another idea.
Old Oct 24, 2012 | 03:28 PM
  #34
Wilson01960196
I hope sohaha
Old Oct 25, 2012 | 12:51 PM
  #35
Wilson01960196
I hope sohaha
Bumpp
Old Oct 25, 2012 | 12:57 PM
  #36
Izero's Avatar
Izero
go download the factory service manual and check the rest of the grounds.... idk what else to tell you...
Old Oct 31, 2012 | 08:08 PM
  #37
Wilson01960196
New update..i have discovered that even wgen uts cold outside it works fune until the inside of the cab warms up from the heater then it alowly starts messing up..warmer it gets in the cab tge worse it is???
Old Nov 2, 2012 | 09:17 AM
  #38
Izero's Avatar
Izero
When was the last time you changed the timing components, including the oil & water pump?
If the answer is never or more than 60-100k miles ago then I would suggest changing those all out just for peace of mind.
But the fact that the truck runs "better" when it is cold is very odd, I think it's time to take it to the dealership and have them give it a real good look.
Old Nov 2, 2012 | 01:12 PM
  #39
kenneymc's Avatar
kenneymc
Need to figure out what the speedo and turn signals have in common in the instrument panel.....referring to your original post. Need to take a look at the service manual and analyze it, see what you can find in common.
So as cabin heats up, problem gets worse? What if it is cold outside, and you don't run heater in cabin? Trying to figure out if problem is in cabin, or maybe in engine compartment as it heats up too the more you drive and run it. If it stays the same when you drive, and heat off in cabin, but then after a while, turn on heater, then it starts getting worse, then I would focus on the culprit being inside the cabin.
Old Nov 3, 2012 | 12:04 PM
  #40
Wilson01960196
yes when it warms up unside the cabin it does it so i believe its in the cabin somewhere
