Last edit by: IB Advertising
Browse all: Electrical Guides
- Dodge Ram 2002-2008: How to Replace Ignition Coils and Spark Plugs
Step by step instructions for the do-it-yourself repairs
Coil packs are stuck
I wanted to inspect my spark plugs today but found that my coil packs are completely stuck to the plugs.
Is there anything I can do to make removal easier?? Obviously they haven't been cared for for a long time.
I need to do some work for sure....I'm getting 9.5MPG, my dads 5.7 hemi is getting 19.5 .... lol.
if I recall there are small bolts that hold each coil on, which might be under a little cover on the side of the coil pack somewhere... if you've already taken those off then sometimes you just need to pull a little harder... I would advise against trying to wedge them out though...
oh and on a 2002 Magnum (5.9L) powered 1500 you probably won't see over 14 MPG, ever....
I also guarantee that 19.5 is highway compared to your 9.5 city. I just changed my plugs 2k miles ago and I still can't get over 9.5 city so don't expect a gain. But as for your issue the coil packs are suctioned in the plug hole (not proper terminology) so they do take some elbow grease to get out. But if you have an 02 you don't even have coil packs so now I'm confused.
Just pull the crap out of them and they will come out... just replace the wires while you're at it... enjoy.
My old man also hasn't been on the highway for a long long time. his truck is strictly city driving.
The ACTUAL problem is a knocking lifter and probably sludge and crap in the engine....nothing terribly serious.
Anyway I've pulled as hard as I possibly could, and I've got some size about me so I'm slightly scared to keep pulling on them and have to buy new coils cause I broke one (or several) trying to change the plugs.
Trending Topics
I'm an electromechanical engineer. "Coil Pack" may be the wrong term, but trust me I'm pulling on the "Coil-over-plugs"
While I don't have a picture at the moment, I wasn't the one who mentioned wires.
It does have a small plug/clip otherwise it wouldn't fire
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
I have a 4.7L engine, there is no distributor and no plug wires. I'm sure my plugs aren't firing magically.
The only other things to pull on are t he fuel injectors and they're stufed under the fuel rails.
Believe me, these things are stuck solidly, and yes I did unscrew the nut holding it down, and I pulled as hard as I could, wiggled slightly, twisted a bit as much as could be allowed and still these friggin things did not budge.
Well we'll definitely need a picture then or else those things are just melted to bore the plug is in. And I meant wires as in the pre 06 Hemi's plug wires that can be easily changed out and should be changed out (not sure about 4.7s) as opposed to the "plug and play" I have on my 08 which utilizes coil packs. I guess my phrasing was off as well lol. What year is the engine?
