running lights and parking lights will not turn off!
Old Jan 3, 2013 | 05:26 AM
rought's Avatar
rought
Make sure you don’t spray the lacquer clear over corrosion because it can still get worse. Try to clean it off gently then clear it. Hopefully you won’t have to solder the jumper wire like I did. Once its cleared it would be very difficult to solder too.. If you do have to get a replacment Im not sure if they fixed the problem either it may do the same thing again..
even though love my truck,,,, I have had a lot of problems with my Electrical system.
Old Jan 3, 2013 | 08:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And posting pics of how you do yours is always good also
Old Dec 8, 2014 | 02:30 AM
dgmn2376's Avatar
dgmn2376
Originally Posted by tedberchtold
thanks a bunch! after reading through the thread it appears that his problem and mine are absolutely identical!
i am just hoping that if i tear into my fuse box that i can solve mine with just a couple coats of lacquer like he did!!
its only going to be in the mid 20's for the next few days and i dont have an inside space to do this so i am hoping it isnt a long job to get the board out??
with having to drill the tabs and whatnot it sounds intensive!
I have 2008 dodge ram diesel wonder if it would be the same problem? it is only the passenger side marker lights and the roof lights that are on and wont shut off.
Old Dec 8, 2014 | 10:40 PM
rought's Avatar
rought
no problem was fixed after 2005..
Old Dec 10, 2014 | 08:47 AM
Izero's Avatar
Izero
It's more likely a problem with the Light Switch and/or TIPM on your 2008 Ram...
Old Sep 5, 2019 | 06:07 PM
BBICLBIC's Avatar
BBICLBIC
one more update:
after a trip to the local auto parts store i have found out that the alternator and the battery are both in working condition!
since arriving back home i have disconnected both terminals and i am leaving it set for now.
Did you figure the lights staying on issue ? I have the same issue last night with my 2004 Dodge durango 5.7 .I am pulling my hair out .Thanks for help .
Old Sep 5, 2019 | 09:26 PM
Read thru this thread. Something about corrosion on the switch terminals? (I didn't read the other thread.)
