Hesitant Start
Old Feb 28, 2019 | 09:24 PM
  #31
72rtchallenger's Avatar
72rtchallenger
Originally Posted by GaRamGuy
Got it. I am going to autozone to rent their fuel gauge at no charge. I will keep you posted. Thanks for help!
Were you able to check an see if pressure leaked off ,,as it could bleed off back into tank
Old Feb 28, 2019 | 09:32 PM
  #32
GaRamGuy's Avatar
GaRamGuy
The silly gauge did not work. I went back and got another and it too was messed up. No readings. I have to go find another guage.
Old Mar 6, 2019 | 11:45 PM
  #33
GaRamGuy's Avatar
GaRamGuy
New throttle body. Starts better but will hesitate less. Ugh
Old Mar 12, 2019 | 07:18 PM
  #34
GaRamGuy's Avatar
GaRamGuy
So I was finally able to get a fuel gauge. With key turned on the reading at the fuel rail was about 52 psi. I started truck with reading at almost 60 psi. Let truck sit for two hours. The fuel gauge steadily dropped. In less than two hours, it was reading zero. Now What??
Old Mar 12, 2019 | 07:19 PM
  #35
GaRamGuy's Avatar
GaRamGuy
Is this normal?
Old Mar 12, 2019 | 08:22 PM
  #36
72rtchallenger
If after a few minutes you can notice a pretty good drop in pressure I would there is an issue,,,check pressure at idle and see if its steady
Old Mar 12, 2019 | 10:03 PM
  #37
GaRamGuy's Avatar
GaRamGuy
Pressure at at idle was fluttering between 57-60 PSI. I had to raise idle before it stabilized at about 60 PSI.
Old Mar 12, 2019 | 10:05 PM
  #38
GaRamGuy's Avatar
GaRamGuy
I did not stay and watch it drop for long. It was slowly dropping. I left it and went back about two hours later, it was down to zero.
Old Mar 12, 2019 | 10:06 PM
  #39
GaRamGuy's Avatar
GaRamGuy
Am I looking at replacing fuel pump. Regulator is in tank, I believe.
Old Mar 13, 2019 | 10:53 AM
  #40
If pressure comes up to over 50 as soon as you turn the key on, fuel pressure isn't your issue.
