P0205 Code replaced injector no help
Old Jan 3, 2020 | 11:43 AM
Harley36's Avatar
Harley36
Default P0205 Code replaced injector no help
I have a 2004 Dodge Ram 5.7. Driving home it started running very rough and died at stops. It would restart but only if I gave it gas. Check engien light finally came on with a P0205. Changed the number 5 injector, but no help. Checked compression in number 5 and had about 120. Checked the wires and tested with a light and it is getting a pulse at injector connector. Any ideas?
Old Jan 3, 2020 | 11:56 AM
Take a look at the connector, sometimes they don't make good contact with the pins on the injector, and you get poor performance. Aside from that, it seems that everything is working as it should..... except.... it isn't. Check resistance on the injector. Maybe a bad part right out of the box?
Old Jan 3, 2020 | 02:23 PM
Harley36's Avatar
Harley36
Looked at connection and can not see a problem. Checked resistance and read 11.9 sometimes 12. Check another one on same side and got 12.1. Truck will start, but only if I pump the gas, and will keep running as long as I am giving it the gas. Once I let off the gas it will die.
Old Jan 3, 2020 | 02:47 PM
Try swapping the injector with another one, see if the problem follows the injector.
Old Jan 3, 2020 | 03:49 PM
Harley36's Avatar
Harley36
Thought about doing that, but now I no longer get a check engine code. It still runs bad and hard to start but no codes of any kind.
Old Jan 3, 2020 | 06:35 PM
How old, and what kind of spark plugs? Done anything to the truck lately? Is this something that kinda crept up slowly, and got progressively worse, or, did it just start running like crap one day.
Old Jan 5, 2020 | 12:09 PM
Harley36's Avatar
Harley36
Changed plugs about a year ago. Replaced EGR about a month ago. All was running fine until this happened.
Old Jan 5, 2020 | 04:09 PM
Swap the injector with another one. See what happens.
Old Jan 10, 2020 | 01:09 PM
Harley36's Avatar
Harley36
Not sure the problem is with the injector. No longer getting a check engine code of any kind. Can only get it to start by pumping the gas and can only keep it running by giving it gas and holding it at 2000 or more RPMs.
Old Jan 10, 2020 | 01:58 PM
TrueDogman's Avatar
TrueDogman
Should have thrown a code but make sure your new egr isnt stuck open.
