Fuel leak at rail
Old Aug 10, 2021 | 10:56 AM
bdhuntr's Avatar
bdhuntr
Default Fuel leak at rail
I have a small fuel leak at the fuel rail where the fuel line connects. I am having a difficult time finding a part number for the fuel line. Does anyone know a good source for this line and the correct part number? It’s for a ‘05 1500 QC 4x4 with a 4.7L engine.
Old Aug 10, 2021 | 03:03 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
https://www.mediafire.com/file/rukzn...anual.pdf/file
Old Aug 10, 2021 | 08:09 PM
Should just be a couple o-rings in there.... Maybe only one. Should be able to match it up at your local parts store.
Of course, it may be that the line is just to corroded to seal properly too....
Old Aug 10, 2021 | 10:06 PM
bdhuntr's Avatar
bdhuntr
I cleaned the line and pressurized the fuel system. I found a small pinhole spraying fuel. Definitely not an o-ring issue.
Old Aug 11, 2021 | 03:55 PM
jrsick's Avatar
jrsick
Your fuel rail quick disconnect fitting looks ok from here.
You'll need a fuel line disconnect tool.
I wouldn't order the new fuel line online. I'd go to a dealer or a auto line specialty store, you'll need to talk to someone to get the right part.
Old Aug 11, 2021 | 10:17 PM
bdhuntr's Avatar
bdhuntr
Yeah, the fitting is fine. For now I sealed the pinhole with some JB Steel Stick. I removed the rust with naval jelly and sanded it after rinsing. Looks like crap lol but sealed the leak for now.
Old Aug 12, 2021 | 06:29 AM
jrsick's Avatar
jrsick
There is another fitting at the other end of that flexible line. I believe you have a hard line coming forward from the fuel pump that terminates below the engine. There's a flexible fuel line that connects between the hard line and fuel rail.
The other end of that flexible line could be steel, just like in your picture, or possibly plastic with a push-button release. The fitting will likely be covered with wire loom or nylon sheathing.
I've received good fuel line products from Russell Performance. The lines I've ordered were anodized aluminum fittings and stainless steel braided flex lines.
Old Aug 12, 2021 | 01:58 PM
Dodgevity's Avatar
Dodgevity
On what, the hose or the rail?
Old Aug 12, 2021 | 02:21 PM
bdhuntr's Avatar
bdhuntr
The line, not the rail. About 3/8” before it makes the bend towards the rail.
Old Aug 21, 2021 | 11:16 AM
bdhuntr's Avatar
bdhuntr
So much for the quick fix. Starting leaking again. Got to replace the line.
