Water leak
Old Jan 26, 2022 | 10:08 AM
AnotheRam's Avatar
AnotheRam
Default Water leak
When it rains I end up with water under the rear passenger seat in the storage area. I clean the little drain hole out under the sliding rear window channel but it still gets wet.Any ideas on how to stop the water from coming in?​​​​​​​
Old Jan 26, 2022 | 10:27 AM
Is it coming in thru the brake like at the top of the cab?
Old Jan 26, 2022 | 10:46 AM
jrsick's Avatar
jrsick
yep, that leak is usually from the third brake light. The lens is mounted at the rear of the roof line, right where it curves down. A thin coat of clear silicone on each side of the brake light gasket will probably fix it.
Old Jan 26, 2022 | 11:27 AM
Alex Medeiros's Avatar
Alex Medeiros
I'm with everyone on it probably being the third brake light. The gaskets tend to go bad after a long time.
Old Jan 26, 2022 | 11:57 AM
AnotheRam's Avatar
AnotheRam
Default Water leak
Thanks, I'll check that out once the weather gets above freezing. would water coming from the 3rd brake light go into the sliding window channel
Old Jan 26, 2022 | 12:07 PM
Dodgevity's Avatar
Dodgevity
Is your rear window glass original, or was it replaced at some point?
Old Jan 26, 2022 | 12:23 PM
AnotheRam's Avatar
AnotheRam
Default Water leak
It is original
Old Jan 26, 2022 | 12:58 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by AnotheRam
It is original
I asked because I had water coming in due to the rear glass not being properly sealed. I replaced the glass and managed to still screw it up somehow, so there I was again with another leak.
Rather than pull the glass out all over again, I deluged around the perimeter with a garden hose and located the new leak in the upper right corner. Let it dry really well, then I then squeezed in almost a whole tube of flowable silicone into the area over two applications and it resolved the problem. The stuff flows, so it settles and finds the holes before drying. Prior to all this, I thought it was my 3rd brake light too, but after hosing it down and pulling it off, it was bone dry in that location.
Old Jan 29, 2022 | 11:54 PM
lxman1's Avatar
lxman1
Site Moderator
It's usually the 3rd brake light as mentioned. I sealed mine with clear windshield silicon as well, before it started leaking, years ago.. The only other possibility, if not the window seal itself, would be the satellite radio antenna on the roof if you have one.
