Occasional hard start/sputter
Old 03-22-2023, 09:10 PM
Concept225's Avatar
Concept225
Concept225 is offline
Default Occasional hard start/sputter
This issues driving me crazy. After my truck sits for at least an hour it sometimes won’t start right away. It’ll crank and sputter and take a few cranks to start. Noticed it helps if I hit the gas pedal. It has no codes, 57lbs of fuel pressure. Changed crank and cam sensor, new fuel injectors. Cleaned throttle body. Anybody have any suggestions? Thanks
Old 03-23-2023, 08:21 AM
jrsick's Avatar
jrsick
jrsick is offline
More info would be helpful. What year and engine? Have you had any significant events, like an overtemp, or maintenance done on the truck? Has truck always run fine and now suddenly hard to start?
Take a look at your plugs and check battery grounds. Let someone start the truck while you observe, and smell, the exhaust on startup.
Old 03-23-2023, 03:32 PM
Concept225's Avatar
Concept225
2005 5.7. Nothing out of the ordinary, just started happening. Plugs done last year, just did the ignition wires, cleaned pcv valve. Runs great after its running. It does smell a bit rich. I’ll check grounds. I checked a few plugs and they looked good but I’ll check them all to be sure.
Old 03-23-2023, 07:20 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Just when cold? Or is it really random?
Old 03-24-2023, 09:27 AM
Concept225's Avatar
Concept225
Yea it doesn’t happen once I get it running, it’ll start perfect over and over again. But after an hour is when it starts happening. But sometimes next day it starts right up.
Old 03-24-2023, 09:57 AM
Need a scanner that can read live data, and see what things look like when the engine is cold.
Old 03-25-2023, 10:27 AM
Concept225's Avatar
Concept225
Any idea what to look for? I have a decent one that has live data and don’t see anything out of the ordinary.
Old 03-25-2023, 10:29 AM
Dig thru the data, engine not running, see if sensor readings make sense. Some won't show anything at all, as they are not active with the engine off. (O2 sensors, for instance.) Biggest ones I would be concerned with are engine temp, and map sensor. Throttle position sensor as well.
Old 03-25-2023, 12:43 PM
Concept225's Avatar
Concept225
Engine temp was also 45. Appreciate your help!
Old 03-25-2023, 12:51 PM
Well, that looks right..... How is fuel pressure first thing in the morning?
Quick Reply: Occasional hard start/sputter
