⚠️ Driver Seat Stuck Forward ⚠️
It’s been a VERY intermittent problem till now but it seems as though the motor the motor that controls the front to rear power movement of the driver seat is shot to 💩.
I moved it forward so my wife could get in the back with our 2 month old then the seat refused to go backward. You can hear the motor click to engage if you try to move the seat forward, but no response at all if using the switch to move the seat to the rear.
I couldn’t see a PN on the motor but a Google search led me to 5509070H. It’s apparently difficult AF to find, but I need one because currently it’s parked at my in-laws because I’m 6’4” and can’t even imagine fitting between the seat and dash.
So I’m asking for some help locating the right motor and getting it swapped out so I don’t have to hire some little Asian girl to drive my truck to the shop so they can fix it.
Thanks!!
2006 Ram 4x4 Laramie 5.7L HEMI
Thanks!!
The following 2 users liked this post by aleekat:
FabricGATOR (07-02-2023),
John-RAM-03 (07-13-2023)
+1 on what aleekat said. It seems that the switch is only connecting in the one direction.
Now I only have manual seats but sometimes you may be able to spray some DeOxid (my favorite) or some other electrical contact right into the switch without even removing it.
But again, I can't see your switch to know if that is even possible.
I saw the switch on the video above. Maybe can get Contact Cleaner on that joystick BUT what the man did by using the other motor circuit to operate the forward/back motor is probably your best bet and then order a switch.
Might be common enough a problem that an aftermarket switch might be available at aaaAutoZona or similar today!
... and now, my prerecorded statement:
I hope this helps you.
Please return and tell how this information worked for you, what you find, and how you eventually fix your vehicle (even if it is that you brought it to a mechanic / dealership for repair)
It is your feedback and final repair report that will make these forums useful to others in the future.
Many times I search and find the same exact fault that I am having, someone suggests how to fix it, the patron follows the suggestion and then never returns to say yea or nea...
The forum thread just goes dead because the person fixed their fault and has not a care to offer the answer anymore. Please don't be that guy.
Cheers!
Cheers!
AKCallahan (07-03-2023),
FabricGATOR (07-03-2023)
Happy to report the new switch fixed my issue!
Once I put the plastic cover back on the switches itself, I noticed it stuck a lot even though it was clean on the back end. Upon further inspection, one of the plastic tension tabs had broken, and caused the switch to get stuck however slight in the direction you were wanting to go. My assumption at this point is that at sometime, my switch got stuck in the backward position and simply burnt out that direction.
Nevertheless, $50 part from O’Reilly’s and I couldn’t be happier.
AKCallahan (07-07-2023),
FabricGATOR (07-08-2023)
Trending Topics
Mopar didn’t offer a lifetime warranty but this aftermarket part did. I’ve done aftermarket parts all over my 2006 Charger and Ram, without having to redo any work in the 14 years I’ve had them. I just simply encourage people to use Mopar sensors. Always do that.
I learned a long time ago that the only guarantee I got with those white box parts was that I was going to spend a lifetime replacing them for free.
I freaked out when I realized the Advanced Auto parts had a professional desk ProToCall... I realized that all the mom and pop mechanics are going to start putting Advanced junk parts on my mom's and uncles' cars. Geeze
