Mega Cab AC sucks!
Old Jun 10, 2011 | 09:57 PM
  #121
Matt99's Avatar
Matt99
I have been complaining about how long it takes to cool the truck. Maybe I need to try and do the valve thing, my grandpa has been doing it in his trucks for 20 years
Old Jul 23, 2013 | 02:12 PM
  #122
MichaelHartz's Avatar
MichaelHartz
Default Mega cab a/c problems
I am a top of the cummins tech and that leads to the truck side a lot. I just got through pulling the dash and removing the 2 screens in the top of the air box and it works great. Air flow out of dash is good and the air flow out of the rear vents is still good. The a/c system is the same system ford and chevy have been using for years. Compressor, orfice tube etc. The only other problem I have had with the dodges is the compressor coming apart and pushing debris into the condenser. It is also a wise idea to put a piece of window screen right behind the grill to keep road debris from hitting the condenser. remember it is the first thing the air has to flow through. I also tell my customers to externally wash the condenser at least once a year using simple green and a water hose. as the condenser heats up it acts like a magnet for road grime bugs etc. If you do these few things it should work like a champ.
Old Jan 13, 2018 | 06:24 PM
  #123
MartinF's Avatar
MartinF
I have a air conditioning issue
it was totally replaced, compressor dryer fan clutch and condenser
now it smokes I it’s not on and also sometimes smokes when on and running
i do have cold air but we do t use the air much.
Real pain to have to run continuously
Old Jan 14, 2018 | 08:51 AM
  #124
Smoking out the vents, or under the hood?
Old Jan 14, 2018 | 09:57 AM
  #125
MartinF's Avatar
MartinF
It smokes from under the hood Usually the passanager side
Old Jan 14, 2018 | 11:25 AM
  #126
Where is it coming from???
Old Jan 14, 2018 | 12:26 PM
  #127
MartinF's Avatar
MartinF
That’s the issue Every time it happens I’m on the lights / driving Usually from the passages side As soon as I see it I pull over .. then no more smokeConditioner is hot but not burning hot Smoke smells chemicals / plastic burning Guessing clutch?? But again can’t prove it yet
Old Jan 14, 2018 | 01:05 PM
  #128
MartinF's Avatar
MartinF
That’s the issueEvery time it happens I’m on the lights / drivingUsually from the passages sideAs soon as I see it I pull over .. then no more smokeConditioner is hot but not burning hotSmoke smells chemicals / plastic burningGuessing clutch?? But again can’t prove it yet
Old Jan 14, 2018 | 01:20 PM
  #129
Could be...... Gonna be fun to find that one. Maybe run the engine at high idle in park, with the hood open, see if anything presents itself?
