breaking tires free 4.7 qc
i have a 2006 qc 4.7L 2wd and when i use the power breaking method i can get one tire to spin real good......but sumtimes i get both tires to spin........what should i get to help me out i want both tires spinning.......only mod i have is the air ram power wire.....
RE: breaking tires free 4.7 qc
Do you have an open diff or the limited slip?
If it's open, then getting both to spin will be hit or miss.
If you really want them both to spin on demand, you need to add a locker or a GOOD limited slip (Detroit TrueTrac).
Otherwise, once one wheel breaks free, the othe one gets little to no power.
If you really wanna put on a good smoke show, put some bleach under the tires. Doesn't smell quite as yummy as just rubber, but you sure won't have any skeeter problems for a while.
is the install really $620 for an auburn? [:@] Is that with the lsd included or did you supply the part? I found some brand new auburn posi's for $380 and i'm not looking to spend $1000 buying and having a posi installed. When I do it I am also going to 4.10 gears.
Trending Topics
ORIGINAL: motorider228
If you're are just swapping diff's, you "usually" can get away with not resetting everything.
Find a GOOD shop if you are gonna do this. And I mean a guy that has done gears and diff's for years and years. It is so easy to screw up a gear install, it's not even funny. You get these friggin monkeys that think they can setup a gear set and the next thing you know, 100 miles down the round you get this god awful whine and not to much farther you lock up the rear end.
Do some homework before you let anybody tear into your gears.
