Climate Control Panel quit working
Old 10-25-2011, 06:35 PM
dmoney74's Avatar
dmoney74
dmoney74 is offline
Exclamation Climate Control Panel quit working
I have a 2010 Ram 1500 and my Climate Control Panel doesn't work anymore unless I take out and put back in the certain fuses 16, 28, 42 and 47 (all showed HVAC in description in manual) before I start the truck. If I don't reset fuses the climate control **** lights don't work and it only blows outside air at the feet regardless of **** position and tempature position. Also there is no heat even if control panel is working. Is something "tripping the breaker" for lack of better words, whats the deal?
Old 10-25-2011, 08:50 PM
Mikeyyy816's Avatar
Mikeyyy816
Mikeyyy816 is offline
Something is prob. shorting out...it's a 2010 bring it in under warranty...
Old 10-25-2011, 10:10 PM
dmoney74's Avatar
dmoney74
dmoney74 is offline
I think the warranty may be out now, I have 41k miles?
Old 10-26-2011, 01:35 AM
LU229's Avatar
LU229
LU229 is offline
It may fall under the Heater & A/C recall, mine did and they re-flashed it, now works fine. (mines a 2010 QC 4x4 HemiSport)
Not sayin this will fix yours, but its worth a shot to call the stealership and find out if covered or not.
Have your VIN# number ready when you call them, they`ll need it to find out for you.
GOOD LUCK..!
Old 10-26-2011, 09:26 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
DMoney,
The recall #'s that may pertain to your vehicle are L14 and K17. If you are going to call the dealer ask about those specifically.
Old 10-26-2011, 11:20 AM
dmoney74's Avatar
dmoney74
dmoney74 is offline
I will look into the recall and the recall #'s, that will be awesome if I'm covered still, fingers crossed.
Old 10-26-2011, 11:38 AM
dmoney74's Avatar
dmoney74
dmoney74 is offline
Just called dealership and they said its covered under Recall K17 and they can fix it in 30 mins. Thanks for the help everyone, I was about to put down some cash for some diagnostics so you saved me time and money!
Old 10-26-2011, 02:48 PM
DodgeCares's Avatar
DodgeCares
Dmoney,
If you want to PM me your VIN I can check for other recalls. Sounds like you may not have received them or have the dealer check while your there.
Old 10-26-2011, 07:51 PM
kddsRam's Avatar
kddsRam
kddsRam is offline
As long as no actuators are bad it should be quick like they said. Mine was doing similar as well as this knocking sound in dash but when I flashed the stock tune back before the trip to the dealer, it worked fine for one trip to work but acted up again shortly after. I bet pulling fuses as you did would have done same thing.
Old 10-27-2011, 01:27 AM
LU229's Avatar
LU229
LU229 is offline
Good bunch of guys in here, they`re ALWAYS glad to help out any way they can.
Keep us updated on the outcome. Be interesting to see what and if this recall fix`s it.
Quick Reply: Climate Control Panel quit working
