Old Aug 13, 2015, 07:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
RADIO and BACKUP CAMERA PROBLEM on a new 2014
Old Jul 28, 2014 | 11:57 AM
  #71
Dusty48's Avatar
Dusty48
Originally Posted by Ram Tuff
I have a brand new 2013 sport , not even 2 months old with 4000 Kms , and the radio wouldn't shut off. I had to take the battery cable off to get it to work properly. Two weeks ago the remote to unlock the doors stop working , but after I took the cable off , it works now. Love my truck , but sure is annoying to have these problem already . I also have a 2012 journey R/T awd that has had radio problems to the point of having it replaced a month ago.
I'm not sure which radio and interface you have, but on mine I suspect that the radio doesn't switch off by design.
If you notice, pressing the Volume Control **** really only mutes the receiver and I believe that is done that way so as to keep the amplifier section active for other purposes, such as messages. On mine I have a separate Screen On/Off button.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 004700 miles.
Old Aug 24, 2014 | 09:31 AM
  #72
fargo39's Avatar
fargo39
Read the posts about the radio problems so when i bought my ram i figured the radio might give me some problems. Two days later started switching to aux. The next day hit a water puddle not very big then service 4wd servo light came on. I had dropped it off they replaced the media hub and 4wd servo. So far so good .
Old Sep 20, 2014 | 05:53 PM
  #73
garamhansol's Avatar
garamhansol
Default Lemon Law?
2014 laramie. Having same problems. Awaiting for a new radio and this is 3rd dealer's try. I'm going to file a lemon law if it does not get to be fixed this time.
Old Sep 21, 2014 | 01:35 PM
  #74
Norge1113C's Avatar
Norge1113C
Default Radio
It is not the radio it is the USB port in your console. Once they replaced that in ours radio problem stopped. So let your dealer know that and if he needs to tell him to talk with john at Antioch dodge in California
Chrissy
Old Nov 4, 2014 | 05:56 PM
  #75
msantangelo's Avatar
msantangelo
Default Radio/backup camer issue
I have the same truck, just had a similar issue today. Rear signal, backup camera and radio display issues. The dealer found a bad ground in the rear left corner near the taillights.
Old Nov 5, 2014 | 10:21 AM
  #76
LeeT73's Avatar
LeeT73
Default Faulty Input Module in Console
Hey All,
Not sure if I posted this or not (I certainly meant to, but life happens). Nonetheless, I can confirm that the problem appears to be a fault in the input module located in the arm rest. I determined this after plugging in a 1/8" stereo cable, which I leave plugged in at all times (with nothing connected to the other end). This resolves the problem of the input erratically glitching to Aux.
Interestingly, I told my dealer this the moment I brought my truck in to repair. I work in the electronics/instrumentation, and I know a bad ground when I see one.
Anyway, this 'temporary' fix (leaving 1/8" cable plugged in) works in my case, so be sure to give it a try.
Also, please let us all know if replacing the input module in the arm rest actually fixed the problem for you. Perhaps one of these days I will find the time to do the same.
Thanks.
Old Nov 11, 2014 | 10:36 AM
  #77
Hitman59's Avatar
Hitman59
Default Kenwood KVT-516 backup camera
I just purchased a 2008 Bighorn which had this system, but when you put the truck in reverse, the screen changes but no video shows from the cam...any suggestions TIA
Old Nov 23, 2014 | 02:28 AM
  #78
24Gordon's Avatar
24Gordon
Originally Posted by andrew_nomi
so apparently now they said that replacing the center stack wont fix the issue and they are waiting for a new software update and have no eta.
Made a youtube video of the issue. Anyone having a similar problem?
2014 dodge ram 1500 radio problem - youtube
im having the same problem with my 2014 dodge ram 1500. It just started this last week, but its getting worse all the time. Going to call the dealership monday.
Old Nov 26, 2014 | 08:04 PM
  #79
Musadl's Avatar
Musadl
I am having the same problem, had the update done about three months ago, still switched randomly from radio to connect aux. Brought it in yesterday to have it fixed was told they did an update. I told them it already had the update was told a new update came out two days ago. Five minutes down the road it started switching back and fourth again. Am bringing it in next Tuesday, hopefully they will finally fix it.
Old Dec 15, 2014 | 06:57 PM
  #80
bullridge's Avatar
bullridge
Yup, 2014 Laramie here too. Radio randomly switches back and forth from aux. Dealer and customer service no help whatsoever. I too am looking at filing a claim under the lemon law.
