Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Kicker 750.1
Old May 8, 2007 | 09:20 PM
  #21
cr80renob's Avatar
cr80renob
Default RE: Kicker 750.1
Haha Man I will have Kicker coming out of my ears then won't I?! Kicker amps, Kicker subs, and Kicker wire!!!
Would this wiring kit work?
Thanks again for all of your help!
Shane
Old May 9, 2007 | 04:13 AM
  #22
habeba86's Avatar
habeba86
Yes it will work fine, jst dont forget 2 sets of rca's.
Old May 9, 2007 | 04:15 AM
  #23
cr80renob's Avatar
cr80renob
Sweet!
I will be sure to buy the two sets of rca's! Thanks man!
How much is a good set of rca's?
Old May 9, 2007 | 04:21 AM
  #24
cr80renob's Avatar
cr80renob
P.S- Is there a brand that is better than another? What brand do you prefer?
Old May 9, 2007 | 04:23 AM
  #25
habeba86's Avatar
habeba86
http://www.sonicelectronix.com/item_...le+05KI25.html
http://www.sonicelectronix.com/item_...le+05KI22.html
Circuit city has tsunami rca's that will work jst as fine also.
Old May 9, 2007 | 04:26 AM
  #26
cr80renob's Avatar
cr80renob
With the Kicker two channel, I would only need one pack right?
Old May 9, 2007 | 06:15 AM
  #27
habeba86's Avatar
habeba86
ORIGINAL: cr80renob
I dont know what your sayin? I gave two links, bcuz you will need the 16.5 foot one to run from the back of the radio into the first amp. Then you can use the outputs in that amp and run the 6.6 ft to the second amp. If you added another 2 channel you would need another 16.5 foot cable.
Old May 9, 2007 | 01:21 PM
  #28
cr80renob's Avatar
cr80renob
Alright, I get what you're saying! So I would run the 16.5 ft one from the back of the radio to one of the amps, then take the 6.6 ft from the first amp (one that's plugged directly to the radio) to the remaining amp. That would work just as well?
Old May 9, 2007 | 02:01 PM
  #29
rtkota5point9's Avatar
rtkota5point9
Yes, the amps have a pass-through. It works great.
Old May 11, 2007 | 11:08 PM
  #30
cr80renob's Avatar
cr80renob
Alright.... I bought the two cables you recommended habeba86. I also got this Kicker wiring kit. Is there any thing else that I will need before I have the system installed?
Thanks,
Shane
[sm=confused06.gif]
