Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
46re converter locking up in drive and reverse sometimes
Old Aug 20, 2019 | 09:00 PM
  #41
flathead31coupe's Avatar
flathead31coupe
Disable the vacuum boost. (disconnect the line from the booster, and plug it. Try it again.
the brake booster?or vaccuum pump
Old Aug 20, 2019 | 09:51 PM
  #42
Dammit. Diesel. I keep forgetting that.
Disconnect from the booster. The idea here is, see if the booster is giving you a massive vacuum leak. Although, on der diesel, I don't even know if that would be an issue.....
Old Aug 22, 2019 | 07:52 AM
  #43
flathead31coupe
it was suggested that the spool valve in the valve body is the cause of the slow lock up....thoughts?
Old Aug 22, 2019 | 09:16 AM
  #44
No idea on that. It's possible a sticking valve could cause your problem.
