Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
46re converter locking up in drive and reverse sometimes
Old Aug 4, 2019 | 08:17 PM
flathead31coupe's Avatar
flathead31coupe
Default 46re converter locking up in drive and reverse sometimes
ok i have did alot of reading about this problem.. and not sure whats up. its a 96 ram 2500 all stock, no mods. most of the time the tranny works great shifting od ect... then out of the blue it will want to die coming to a stop, i give it a little throttle then it is fine,,,,may not have any issues for awhile. sometimes at startup it will die when put into drive or rev, again i ride the brake to keep it from dying then its fine again...is there a way to tell if its the converter going bad? here what i have tried, when its acting up going to drive and reverse, i have pulled the trans relay i can here the relay click when i take it out and in...but no help any advice would be great thanks. update its a 47re not a 46re...
Old Aug 4, 2019 | 09:57 PM
Gas or diesel?
Old Aug 4, 2019 | 11:15 PM
flathead31coupe
sry heyyou...its a diesel
Old Aug 5, 2019 | 11:43 AM
Ok. Then 47RE most likely. (slightly beefier version of the 46, and bellhousing is different bolt pattern.)
Could try replacing the TCC solenoid..... fun to get to though. When is the last time fluid/filter were changed? Bands adjusted?
Old Aug 5, 2019 | 05:27 PM
flathead31coupe
i was told the 96 was the first year for the 46re and 95 was the last year for the 46rh but i dont know...it is the 47re...if i change the tcc solenoid what else should i look at in the valve body,was told that there is a valve in the valve body that can be bad and let fluid bypass and lockup the converter
Old Aug 5, 2019 | 06:02 PM
46R? Never came behind a diesel. Not in any year. It won't bolt up. Nor would it survive long behind one.
Old Aug 5, 2019 | 07:45 PM
flathead31coupe
its a 47re sry, when i change the tcc solenoid is there anything to look at as far as the valve body. was told there is a valve in the valve body that will let fluid leak pass and lock up the converter
Old Aug 6, 2019 | 08:19 AM
If you are having any other shifting issues, I would be real tempted to replace ALL the electronics in the trans, adjust the bands, and change the filter since you are going to be in there anyway. Drain plug may not be a bad plan either.
Take a look at what's in the bottom of the pan. Condition of the fluid, etc. Tells a lot about the condition of your trans.
Old Aug 7, 2019 | 10:05 PM
flathead31coupe
thanks thats the plan for now. i will let you know what i find
Old Aug 13, 2019 | 11:02 AM
flathead31coupe
so i took the trans pan off, didnt find anything no metal or anything but the magnet had about a 1/16 of sludge looked like anti seize or grease like...no clue
