evaporator and heater cover
I pulled the ac and heater box/housing out of my '94 dodge caravan 3.0 v6 for heater core and evaporator replacement.
On top of the housing cover, (upper housing/top cover of the box), there is a small see-thru-hole directly above the evaporator chambe.
What is the purpose of this peep hole? It's not a screw hole, but it's there.
Did I miss something during disasemble?
Thanks in advance.
Thanks in advance.
Thanks, perhaps it is ,not 100% sure tho, until maybe I get a definite answer,another issue is that I don't remember seeing the heater core tube seal when the box was removed from the van. Perhaps I misplaced it somewhere and don't recalled?
If the heater core was installed from factory with heater core seal then I dont know how it can be installed without the seal. It's on dealer's cancelled parts list.
Expecting a new heater core from the dealer tomorrow and if the seal is not included in the package then I'll need help finding one urgently.
I'll keep you informed. Thanks.
Thanks Tizzy1 for the advance info about a new heater core doesn't come with seal.I've looked everywhere I can think of,including everywhere in the engine compartment.
Also some have said they believe the hole on the housing cover is probably for the vacuum harness retainers ... confirnimg what you said.
Ebay doesn't have the seal,I searched.Where else? Hmm.
Trending Topics
Thanks, I'm searching if I can get somethig close enough as Tizzy1 suggested.Just as he said ,the heater core package came without the tube seal,it looked ancient,the dealer said that's because its brass so it appears old but its new.
I subscribe to All Data Diy but the information to reassembly the heater core inside the box is not very detailed for me.I was trying to post pictures of heater core inside the box to get your opinion on it, but I'm having difficulty to insert pictures from my document into this post.How is it done? Thanks.
