~ 1998 Voyager, codes P0700 & P0740; Low Batt or Dead Alt? ~
Hello all,
New here because I just bought a 98 Pymouth Grand voyager (please excuse me if this is the wrong place to post). When I got it, it did not have a battery. Threw in a new one and gave it a go, it was pretty much comletely dead when I got it home. Wouldnt even start once I turned her off. The batt has been on charge for a few and I drove it much further and the thing didnt die. Got back home and it started right up after I turned it off.
Now I dont have a way to test the battery, but it does seem like its still charged. But assuming its not, is it possile that the codes could be thrown on a weak charge? Im wondering this as other Dodge vehicles Ive had and still have will throw random codes on a weak batt. That and the van seems to shift quite well. Looking for some direction. Any help would be greatly appreciated. TIA
Early update: Took a multimeter and I had 12.88v with engine off. Ran it in the driveway at idle had slightly lower voltage. Reved it up and would increase voltage ~.15 or so, but only when reved. Sat in the AC a bit and tested again while running, AC and lights on voltage was 11.88 and dropping.
Also, I noticed I couldnt get the Max AC button to work nor recycle air. I did do the AC reset thing because all the lights were blinking. No flashing lights (other than the rear wiper buttons), but now no lights at all ....
Replaced the ALT, the old one was def bad. Unfortunately the code keeps coming back. Ive deleted it twice already. Strangely enough though, the transmission still shifts fine. I can even feel the torque converter locking up. I have noticed the EATX relay makes a loud high pitched noise when I turn off the van. it does this fro about a minute or so. Im heading to town to buy a new one as well as add some Lucas seal conditioner. Let me know what you guys think.
Thanks,
Thanks,
Alright I replaced the relay, as it pretty much broke into pieces when I tried to take it out. That and the same time I put in some Lucas transmission treatment. I didn't realize this before but it must have been shifting much later than it should have because it shifts much better and earlier (forgive me as I didn't notice it wasn't normal as I drive a 6speed Camaro, just not used to it). Code hasn't came back yet but I really haven't drove it far enough yet to give it a chance to come back.
Now I have a new problem. I have a bad top end knock. Definitely valve train related. Strangely though its very intermittent. Sometimes its quite loud, and other times it sounds like a new motor. I really need some direction on this guys. Please help!
