[3rd Gen : 96-00]: 2000 Caravan - wont start -Relay buzzes
Old Jul 12, 2021 | 09:20 PM
nbpt100's Avatar
nbpt100
Default 2000 Caravan - wont start -Relay buzzes
Just changed the plugs, wires and installed a new battery on a 2000 Caravan. The engine turns over slowly and won't start. After trying to start it and turning off the key the shut down relay clicks. It won't stop unless you unplug it or pull the neg wire on the battery.
Ideas on how to trouble shoot all or some of it?
Old Jul 12, 2021 | 11:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Be sure to have a fully charge battery or replace it with a known good battery.
Old Jul 13, 2021 | 09:49 AM
nbpt100's Avatar
nbpt100
Battery is brand new and measured 12.7 Volts before I installed it. The old battery turned the engine over even slower.
Old Jul 13, 2021 | 10:46 AM
master tech
Can you try to use jumper cables hook up to another vehicle and see if the engine cranks over faster?
Old Jul 13, 2021 | 10:53 AM
nbpt100's Avatar
nbpt100
I have a jump box that I could try that with. It is the original starter and I wonder if it is getting tired. Plus the car sat for 3 weeks while we had a lot of rain. Some grounds may be getting corroded. hard to say.
What is the relay clicking from?
Old Jul 13, 2021 | 05:23 PM
master tech
Clicking sounds are sometimes from low battery voltage.
Old Jul 13, 2021 | 11:56 PM
nbpt100's Avatar
nbpt100
I understand your point. In this case the key is in the off position. It may be a bad connection somewhere.... IDK.
Old Jul 14, 2021 | 12:53 AM
master tech
Could be a feed back from a sensor or short to voltage in the wire harness. Do you have a 3.0L 3.3 or 3.8L motor?
Old Jul 14, 2021 | 12:09 PM
nbpt100's Avatar
nbpt100
It is a 2000, 3.3l.. I am going to check all of the grounds that I can by removing cleaning and reassembling with silicon grease. I will also remove the connectors to the computer modules and clean with electrical contact spray and finish them off with a dab of silicon grease. It has been very wet here for the past 3 weeks. Tons of rain and humid.
Old Jul 14, 2021 | 12:11 PM
nbpt100's Avatar
nbpt100
Also I am going to clean the MAP sensor with TB spray. The air filter was abused and had holes in it. Should I remove it from the TB or can I do a good enough job by spraying in the holes in air intake.?
