Common Dodge Neon Repairs and Problems
Old Oct 11, 2011 | 05:44 PM
  #81
Neonblue231's Avatar
Neonblue231
Question Same problem
Originally Posted by BlueThunder07
Hey, I have had a 2003 dodge neon sxt for about a month now. when i bought it everything was running fine. well a week ago. it started to shift wrong. i was scared that it was the transmission. well i looked under my hood and my front top motor mount was broke so i bought a new one and replaced it and it ran great. for twenty minutes, then i got under the car because there was a really bad rattling sound and sure enough my bottom motor mount was broke so i just fixed that yesterday. well its stilll doing it and when i stick on the E brake and stick it in drive there is a real weird rattling sound right next to my timing belt or what ever that belt is called. does anyone have an idea on what it might be...thank you
Same problem; $600.00 later, mechanics say replace middle motor mount as transmission mount looks good. They say %70 chance that will fis the problem. The problem is an erratic vibration and "dragging" sound when car is cold and in gear--even when stopped. Put in neutural and it runs smooth as a top.
Old Oct 11, 2011 | 07:57 PM
  #82
Neonblue231
Originally Posted by N30N
everyone has common problems
1.swaying
2.control arms
3.studdering
4.leaks in the trunk/back seat
its all the same[sm=gobble.gif]
yes! My '02 Neon fills up with water when it rains... . No leaks that I can find. Seems to fill trunk sometimes, but always fills back seat floorboards.
Old Oct 14, 2011 | 05:08 PM
  #83
danboy51's Avatar
danboy51
i need help 98 neon no full or spark and wen i turn the key off the dash lights stay on even whet the obc out and ign out all lights stay on until i pull the fuse out
Old Oct 16, 2011 | 08:29 AM
  #84
swede_x's Avatar
swede_x
I've read that the problem is the seal around the trunk, try replacing that or using some silicon. We haven't had any rain in the 5 days since I got my neon but I'll be checking it out.
Old Oct 16, 2011 | 09:27 PM
  #85
inderc's Avatar
inderc
Question 96 neon
our 96 neon has gauge problems. Speedo, gas and odometer all work intermmitently. Any ideas out there.
Old Oct 17, 2011 | 02:24 AM
  #86
darthroush's Avatar
darthroush
Section Moderator
Taillights seals are much more common to be the problem.
Old Oct 20, 2011 | 05:17 PM
  #87
Rachal_K's Avatar
Rachal_K
Default water in transmission??
2005 Neon SXT Automatic.
The ATF was mixing with my coolant in my radiator-evidence=milky pink fluid in the radiator. Took it to the mechanic to put in a new transmission cooler (outside of the radiator to prevent future problem). He told me that there is water in my transmission and it needs to be taken out and worked on to correct any damage done by the water. Before I took it to the mechanic there was no evidence on the dip stick of water in the ATF. The fluid looked perfectly normal.
Is it possible for the ATF to get into the radiator but the water(coolant) not get into the transmission? I know the pressure in the tranny is higher than the radiator so it seems possible to me.
Old Nov 1, 2011 | 12:45 AM
  #88
Speedro's Avatar
Speedro
hello there guys im looking for a 2004 2005 srt-4 front bumper who can help me with that i have only 200, thanks for your help
Old Nov 3, 2011 | 11:34 AM
  #89
cregger13's Avatar
cregger13
New Member
i have the same problem with my car now and i took it to aamco to get it checked out and they said it was the 3rd cylender had a strong missfire. they told me to replace the ignition coil and the spark plugs and wires. and if that doesnt fix the problem then go onto the fuel rail. i hope that the ignition coil and the spark plugs and wires fix the issue cuz i spent 130mbucks on those three things alone.
Old Nov 4, 2011 | 10:57 PM
  #90
Enrique's Avatar
Enrique
what about the EVAP sistem. i got that code wen my check engine turn on and went to auto zone
