Guilty!!!
Old Apr 18, 2007 | 08:07 PM
  #21
Mayfair's Avatar
Mayfair
Default RE: Guilty!!!
ORIGINAL: Rev800
I elected to plumb the FASS into my existing fuel filter to maintain the (electric) heater and water sensor.
Did you need any special fittings to do the install that way? Any tips for plumbing it up?
Old Apr 19, 2007 | 01:34 AM
  #22
Mayfair's Avatar
Mayfair
I've got all of the brackets and fittings mounted to the FASS now. I can't wait till this weekend to install it.
Have you started yet Jake?
Old Apr 19, 2007 | 01:45 AM
  #23
jakebrake's Avatar
jakebrake
nope, I've got to drive to tacoma tomarrow, will be down there thurs and fri. Kinda sucks, I could have started on it and be driving my brothers truck back and forth to work if it wasn't for training. I've been looking under the hood and I think I am going to try to mount the pump where the stock filter is, looks like there is enough room there, we'll see saturday though. I also got to go to schwab and have 2 tires replaced. they won't balance out so they are replacing them for free.
Old Apr 19, 2007 | 01:50 AM
  #24
Mayfair's Avatar
Mayfair
Why are you gonna ount the pump all the way up there? I though the pumps liked to "push" more rather than "pull"
Old Apr 19, 2007 | 01:54 AM
  #25
jakebrake's Avatar
jakebrake
I do a lot of off road and gravel road hauling and I don't want to take any chances with the filters. As for being easy on the pump, if the stocker can make it 90k up there this thing will have no problems, plus 6 year warrenty
Old Apr 19, 2007 | 01:57 AM
  #26
Mayfair's Avatar
Mayfair
Yeah ... I guess that makes sense.
Did you read this whole thread yet Jake? What are your thoughts on the fuel heater thing?
Old Apr 19, 2007 | 02:03 AM
  #27
jakebrake's Avatar
jakebrake
I really don't have a need for a heater, the temps rarly drop below 18F out here so I'm not using a heater. Also as drew said, the vp44 heats the fuel. If you are concerned though, I would run it through your now empty stock fuel canister as you had described. Right now I'm trying to find a fleetgaurd fuel seperator with a wif sensor in it that will thread to the filter head. I know they make them, I'll just have to find them.
Old Apr 19, 2007 | 02:20 AM
  #28
Mayfair's Avatar
Mayfair
Oh ... I thought you were going to run the coolant lines to the FASS for some reason.
Isn't 18F considered cold to you? I was reading the manual and it says the fuel heater kicks on at temps below 40.
Old Apr 19, 2007 | 02:26 AM
  #29
jakebrake's Avatar
jakebrake
18F is coul out here, but it's dairly common to see those temps in winter. My theory is if the fuel isn't jelling I don't need a heater. Now having said that, it won't take more than $5 in hose and 15minutes to run coolant lines if it's in the engine compartment[sm=confused06.gif]
Old Apr 19, 2007 | 02:29 AM
  #30
Mayfair's Avatar
Mayfair
Where / how do you "tap in" to run the coolant lines from?
