Aux Fuel Tank
Aux Fuel Tank
OMG, the price of diesel is absolutely KILLING me! I read with interest the post on fuel prices around the country. In the "great" NW, I am paying over $4 a gallon and it isn't slowing down. I am getting to move down to the SW this summer and I was thinking that getting an Aux Fuel Tank (40 gallon) wherein I could jump across the border and fill up for half what we are paying here wouldn't be a bad gig. Is anyone running an aux tank now, and if so, is it gravity fed (illegal) or does it have the fuel pump in the tank? What brand are you running and what are your likes/dislikes? Thanks!
RE: Aux Fuel Tank
I want to get a aux tank and run it seperate with some sort of tee so it will enable me to put the wvo in there, and the straight pump diesel in reg tank. just need to find the right tank, fuel pump and plumbing combination. Oh yea and get the extra cash also. I would like to go 90 to 150 gallon with black diamond plate if I can find it.
RE: Aux Fuel Tank
I found this website. and for me it would be a few hour drive. I am going to call them and let them know what I am looking for and see what the price is sometime this week.
http://www.kshmarine.com/truck_tanks1.htm
RE: Aux Fuel Tank
I have the Transferflow 50 in bed tank. Works great, no problems.
http://www.transferflow.com/crossthebedtanks_0.html
RE: Aux Fuel Tank
I've got a 90 gallon home-made tank that gravity feeds into the stock tank. Just be sure to get aluminum and not steel tank. Mine is steel and I've had rust problems. I put a huge fuel filter on it and try to keep it full as much as I can and it has cut down on the rust to almost 0%. I like the extended range. I drove from Nashville,TN to Scottsdale,AZ pulling 10,000+ pounds and stopped for fuel one time going and one time comming back. You can also save money by filling up in places where diesel is cheaper. I avoided paying the higher diesel prices in AZ and CA by filling up in TX on the way in, and again on the way out.
Trending Topics
RE: Aux Fuel Tank
If I had a secondary tank I can start the truck on pump, switch it over for runing it, then switch it back over a few minutes before shut downa nd it would eliminate the cold start issue.
You would also have to "T" off your return line. I don't know of any easy way to switch it back and forth other than a solenoid valve. The pumps are easy since they are already controlled by 12v.
You can pick up some good aluminum tanks and TSC for a pretty good price.
