kero
RE: kero
ORIGINAL: justviper1
well so far so good! i have a bout 7 gallon of kero in the truck now with a pint of 2 stroke oil. i might go down and add another gallon or two tomarrow! the truck is running great on it so far! knock on wood!
If you going to run Kerosene you need at least 5% lube oil for that...
7 x 5% = 44 Ozs...
The "rotary" VE pump (pre '94) and electronic VP-44 (98.5+ 24 valve) VE and VP-44 pumps are fuel lubricated.
#1-D Diesel or #2 Fuel Oil (diesel) only
Alternate fuels listed for the P7100 pump may be used in the VE pump if if 5% lube oil is added.
http://dodgeram.org/tech/dsl/FAQ/die...approved_fuels
Why run Kerosene its got less BTU's by volume... So its going to produce less power hance lower MPG's... Just to risky of a fuel...
http://mopar.mopar1973man.com/2002%2...l/btus/btu.htm
RE: kero
it is free!!! thats the only reason that i am running it! i ran about 200 miles of it so far. the truck is running fine and still feels like there isn't a loss of power. would some plain clean motor oil work for lube. i don't have anymore 2 stroke and don't have time to stop for any tomarrow morning?
Trending Topics
RE: kero
ORIGINAL: mopar1973man
WHOA! More lube needed!!!
7 x 5% = 44 Ozs...
7 x 5% = 44 Ozs...
do you have any expectations on fuel econ?
now for your next mod, build a grill in your bed that way you can cook some steaks while youre idling in traffic.
RE: kero
i really didn't care about economy just because it was free! i just added two quarts of motor oil that i had in the garage. i didn't have time to stop and get 2 stroke or i would have. i think that i am going to top the tank off before i put it back in the garage with regular diesel just to make sure that there is enought lube in it. it should take about 7-10 gallon.
