The Stealth BOMB'r is under the knife
Old 07-28-2010, 08:35 PM
Coal Train's Avatar
Coal Train
Coal Train is offline
Here's the progress today.
Got the head cinched back down.....
Rockers and pushrods are back in.
Gonna run the valves and set the lash, rotate the engine to make sure there are no clearance issues.
The rockers will come back out to put the injectors back in, but it's much easier to run the valves and check the clearance without having to fight the engines compression.
Once they go back in, the lash will get set again.
  #92
Old 08-02-2010, 11:12 AM
Coal Train's Avatar
Coal Train
MUWAAAHAHAHAHAHAHA!!!!
  #93
Old 08-02-2010, 10:39 PM
Coal Train's Avatar
Coal Train
Alright, the motor is all buttoned up, except for the alternator and AC compressor.
She's full of oil, spun it over a few times tonight to make sure everything was good. Tomorrow we'll hook up the oil pressure gauge and spin it over on the starter to prime the system.
Once we see good oil pressure, it's time to stuff it back in.
Got a few small odds and ends to finish up, a few fittings in the fuel system and touching up a few parts, but otherwise it's about ready to go back in.
Probably the ONLY time you ever see clean oil in a Cummins.....
  #94
Old 08-03-2010, 10:49 PM
Coal Train's Avatar
Coal Train
Well, she's ready to go back in now.
Got the last bit of stuff tightened up today.
Just had to swap an AN fitting on the head and add a check valve to the system and it's all good.
Hooked up the battery and cranked her over to prime the oil pump.
Tomorrow it's getting stuff back in.
  #95
Old 08-04-2010, 08:58 PM
Coal Train's Avatar
Coal Train
Well, we got two things accomplished tonight......Jack and Squat.
I figured we'd put the motor in without lifting the cab a bit......yeah, that wasn't happening.
We wrestled with it for an hour or so and said SCREW IT....we'll pull the Chevelle off the lift tomorrow, lift the cab a few inches and drop the motor in.
It just wasn't wanting to play and I was in no mood to mess with it.
But, the rest of the gauges came in today, so it wasn't a total waste.
  #96
Old 08-05-2010, 10:45 PM
Coal Train's Avatar
Coal Train
Well, here's the progress.
Had to lift the cab about 4"-5" to get the motor to drop in without a fuss.
Engines in, fuel system is hooked up, EGT probes are in, water lines are hooked up, cab is bolted back down, front wheels are off.
Should go pretty quick from here.
The next major slow down will be running all the electrical.
  #97
Old 08-06-2010, 12:07 AM
dodgetrucker75's Avatar
dodgetrucker75
dodgetrucker75 is offline
glad to see it in!!!,
is lifting the cab easy? all i did was leave the oil pan off mine, and bolted it up after i bolted the bellhousing to the engine, it was very easy to do it that way...
  #98
Old 08-06-2010, 12:59 AM
Coal Train's Avatar
Coal Train
If you only have to go up a few inches, it's no sweat.
Just undo the 8 body bolts underneath and disconnect the steering shaft.
You can go up 4 - 6 inches without disconnecting the brake lines. There enough flex and bends in them that all you have to do is keep an eye on them as you lift it.
If you want to totally remove the cab, you have to undo the 3 ABS lines and bleed the system when done.
  #99
Old 08-06-2010, 11:29 PM
Coal Train's Avatar
Coal Train
So today we got the rest of the drivetrain in.
Serviced the trans.....didn't look half bad considering this was two years of crap.
Tomorrow starts the wiring.
Not bad for 2 years worth of abuse.....
Adjusted the bands.....
Installed the fittings for the braided lines.....
Exhaust is hooked back.....man I hate that v-band.
And, the sexy new rotors came in today.....
  #100
Old 08-06-2010, 11:59 PM
dodgetrucker75
lookin good...
if ya dont mind, could ya shoot me a price on a 47re build to handel 700hp, no rush, just thinking... i really hate the manual now, especially with the SB DD, it is just way to slow, but i hate autos with a passion, out of about 10 of them i had the best one lasted me 10,000 miles with about a $3000 build, i'm stuck in the middle right know
Quick Reply: The Stealth BOMB'r is under the knife
