Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
engine temperature
Old 03-18-2006, 03:06 PM
willy_srt10's Avatar
willy_srt10
willy_srt10 is offline
Default engine temperature
Hello,
I'm the proud owner of a dodge srt10 and i was wondering if these
water- and oil-temperature readings are normal and not to high,
my oil temperature is 200 degrees farhenheit and water 220 degrees farhenheit.
Thx in advance *****
Old 03-18-2006, 04:07 PM
sysengr1's Avatar
sysengr1
sysengr1 is offline
Default RE: engine temperature
wow. those can't be right. I wouldn't drive that truck w/o someone looking at it immediately. Bring to your nearest dodge dealer.
Old 03-18-2006, 04:13 PM
sysengr1's Avatar
sysengr1
sysengr1 is offline
That is a wonderful piece of machinery. PLEASE don't drive that thing. TOW to you nearest Dodge dealer and have them look it over.
Old 03-18-2006, 10:03 PM
ryans590's Avatar
ryans590
ryans590 is offline
yah the water temp should be at 210 max i dont rember the oil temp max exactley but that is too high im shure
Old 03-25-2006, 02:54 PM
walenator's Avatar
walenator
walenator is offline
I'm a new owner too and I checked with the dealer about the temp as well. Mine runs up to 220 in traffic and oil temp gets over 200. According to the Palmour Dodge in Alpharetta Ga. which is one of the largest sellers of Vipers, the Viper specialist told me this is totally normal. I also checked in the owners manual and these temps are in the normal operating range. Like you, I am accustom to the temp gage moving up till the thermostat opens at 180 and the gage needle staying there. Years ago I heard that manufacturers put in over heat lights instead of gages for similar reasons. The Viper Tech told me to drive it an not worry about gas mileage and that this motor has to break-in. He had nothing but praise for the trucks. Good luck with yours!
Old 03-26-2006, 12:55 PM
Stingray's Avatar
Stingray
Stingray is offline
Those are normal numbers, especially in warmer climates.
Old 04-01-2006, 02:06 PM
azpyroguy's Avatar
azpyroguy
azpyroguy is offline
Mine is only 3 days old... and it runs about 200 or so for oil temp, and about 200-210 for water temp...
Old 04-03-2006, 01:04 PM
Big Perm's Avatar
Big Perm
Big Perm is offline
Mine runs just under 200 for both on the highway.....in traffic with AC on, up to 215 but no warmer....this is in 80+ degree, humid weather....
Old 04-11-2006, 02:24 PM
Burnout_INC's Avatar
Burnout_INC
Burnout_INC is offline
You get the most power out of something when the motor is hot with a cold air/fuel mixture, would explain why dodge has them running hot.
Old 04-12-2006, 03:28 PM
mmmm_torque's Avatar
mmmm_torque
mmmm_torque is offline
As mentioned above...those are normal operating temps for around town driving on a warm day. Water temp runs 200-220 depending your driving habits/conditions. Under full heat soak, you actually lose hp on these engines. You can reduce the operating temps by:
Flashing the PCM to turn the fan on earlier and running a 172' t-stat
Put on a set of 3" mids with HF Cats
Put on a set of thermo coated headers
drain 2 gallons of anitfreeze, fill with distilled water and a bottle of purple ice.
Drive like your gandma borrowed it from reverend Jones
Quick Reply: engine temperature
