1993 Dodge RAM VAN B250 ECU - computer
Old 12-03-2020, 03:24 PM
Edmund Prokop's Avatar
Edmund Prokop
Edmund Prokop is offline
Default 1993 Dodge RAM VAN B250 ECU - computer
Hello from Czech republic :-), I need buy ECU for 1993 DODGE RAM VAN B250 - 5.2-V8. I need ECU model 5602 9108 or compatible. It is a big problem to buy this part. E-shops in the USA has returned my money 5 times already, because the part is not in stock, even though it was in advertising. I need to know some equivalent, because 5602 9108 probably doesn't exist. Cardone 79-7848 (equivalent to RockAuto) also cannot be purchased. I don't have a defective part, it got lost during repairs. Can anyone advise what is the possible equivalent? The number 5602 starts with many types, but may it need 5602 8321? What do the codes 5602 8321 mean? Will it work for 5.2 - V8? Several e-shops have 8321 in stock. very thanks for ideas and help... (And sorry, my english is partly of google-translator)...
Old 12-03-2020, 06:19 PM
nibroc's Avatar
nibroc
nibroc is offline
are you sure that is a 1993 B250 van? In 95 body styles changed..
Old 12-03-2020, 07:52 PM
volaredon's Avatar
volaredon
volaredon is offline
probably an early 94 built in 93.
94 was 1st year for new body just like the pickups.
Old 12-04-2020, 02:12 AM
Edmund Prokop
Exactly! 5/93 built
Old 12-04-2020, 10:00 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
The part number 56029108 crosses over to 56027848 so try seeing if that one is in stock. Also, check eBay for a used one.
Old 12-04-2020, 03:25 PM
Edmund Prokop
Thanks, it si possible, 56027848 is maybe 1:1 as Cardone 79-7848... This part is out of stock at many retailers, I didn't find anyone. Now i bought on Ebay 56028321, it is for 5.2-V8. I hope it works.
Old 12-05-2020, 10:35 AM
alloro's Avatar
alloro
alloro is offline
That number doesn't cross-reference to your computer. Maybe it'll work, maybe it won't time will tell. Often the basics are the same between different ECMs but it's the vehicle options and sensors that will vary.
Old 12-06-2020, 04:28 PM
Edmund Prokop
Thanks, I understand, it's logical. But in the Czech Republic we do not have much experience and knowledge about these cars. Can you advise me where to get information on the detailed use of the ECU in the car? For example, that the 4878 is a 5.2 - V8 - cruise control - ABS - air conditioning - TV ... perhaps there must be a table according to which the mechanics in the service decide which spare part to use. WV service, Toyota, knows that. I don't know where to ask, Dodge can't do it with us - our market is too small, they're not interested.
I hope I write clearly, my English is only basic, i have only 10 lessons ;-/ ... but with my Dodge is it better a better... many problems from previous owner!!!
Old 12-07-2020, 10:27 AM
alloro's Avatar
alloro
alloro is offline
You would need to compare the ECU wiring diagrams pin by pin between your vehicle model and the one that ECU was supposed to go in. Tough job even if you can find both wiring diagrams.
Old 12-16-2020, 10:20 AM
marty mopar's Avatar
marty mopar
marty mopar is offline
1994 part book for the van....your van is a 1994 or newer van not a 1993
CONTROL, S.B.E.C.
56028251 1 w/3.9L Eng., 1994
56028346 1 w/3.9L Eng., 1995
56040763 1 w/3.9L Eng., 1996
56028265 w/5.2L Eng., 1994
56028348 1 w/5.2L Eng., 1995
56040770 1 w/5.2L Eng., 4Spd. Auto. 1996
56040771 1 w/5.2L Eng., 3Spd. Auto., 1996
56027217 1 w/5.2L Eng., w/o Catalyst 1994
56028403 1 w/5.2L Eng., w/o catalyst 1995
56040772 1 w/5.2L Eng., w/o catalyst 1996
56027298 1 w/5.2L Eng., w/CNG 1994
56028314 1 w/5.2L Eng., w/CNG 1995
56040773 1 w/5.2L Eng., w/CNG 1996
56028267 1 w/5.9L Eng., 1994
56028350 1 w/5.9L Eng., 1995
56028479 1 w/5.9L Eng., w/Calif. 1995
56040777 1 w/5.9L Eng., All, 1996
2 1 COVER, Serv. w/Headlamp To Dash Wire
3 04419492 1 INSULATOR
find the one that applies to your van and then use google this way:
56028265 Mopar
see what comes up
also you can find these in wrecking yards here
www.car-part.com
Quick Reply: 1993 Dodge RAM VAN B250 ECU - computer
