Anyone ever heard this suspension noise before?
Old 11-27-2022, 11:14 PM
1991ramwagonextended's Avatar
1991ramwagonextended is offline
Default Anyone ever heard this suspension noise before?
So ive been chasing this damn noise for a year and a half. Noone seems able to find it and it is getting worse. Seems to be when the van articulate/flexes , especially when one wheel raises up while the other doesnt. Odd thing is, it used to sound like a front end noise. So i basically replaced all the suspension upfront. Now it seems to be coming from all 4 corners of the van , especially in the back. I'd be soooo. grateful to get rid of this sound.
VIDEO of rear leaf spring/shock
ill post other videos from the front and the driveshaft in case someone sees something
Old 11-28-2022, 05:45 AM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
Describe the noise. I think I hear a popping from the drive shaft. Have you checked the u-joints yet? On a shaft, a slight noise can be amplified by the tube itself. I hear other noises but with my hearing, not being there hampers figuring it out.
Old 11-28-2022, 12:14 PM
nibroc's Avatar
nibroc
nibroc is offline
front shock mount loose?
Old 11-28-2022, 12:23 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,262 Likes on 3,009 Posts
Shock bolts get torqued to some truly stupid value. Sounds like they just aren't quite tight enough.
Old 11-28-2022, 05:44 PM
How do I go about checking the shock mounts? I can torque the bolts more but is there risk in over torquing them?
I did replace the u joints, admittedly not knowing what I was doing, but I think I got it right on the second attempt.
Old 11-28-2022, 06:14 PM
HeyYou is offline
Shock mounts are either welded (on the axle) or riveted (on the frame) Should just be able to crawl under there, shake the van a bit, see if they move. (they shouldn't....)
Uppers are like 40 ft./lbs. Lowers are something like 100 ft/lbs..... I don't think it is possible to over-tighten the lower bolts.... just don't break 'em.
Old 12-01-2022, 03:49 AM
Snow has prevented me from getting to this. But I happened to recall, when replacing my tie rod ends, the adjustment sleeve I got from moog was different than the one I took off ( it was straight rather than thicker in the middle). Are these for the 4000lbs axle? Do I have the 4000 lbs axle? I remember thinking that the replacements seemed skinnier and less heavy duty than the oem.
Off topic but can anyone clarify for me the concept of greasing your slip yoke? Is this only for 2 piece driveshafts or 4x4? As I understood, the rwd one piece slides directly into the trans and is lubricated by trans fluid, right? I accidentally once greased mine for a few drives and it felt so much nicer (no more of that slip bump thibg when braking) but I washed it out after thinking this would hurt the trans.
Old 12-01-2022, 08:29 AM
HeyYou is offline
One piece shaft doesn't require lubrication, (are there grease fittings on the u-joints? if so, those DO require a couple pumps every now and again.) though, having some grease on the splines won't hurt anything.
Old 12-01-2022, 09:32 AM
ol' grouch's Avatar
ol' grouch
The grease is mostly caught at the seal. It won't hurt anything. On the front end parts, factory parts are often pressed and folded steel. Aftermarket is often machined from a solid piece. If factory is good, aftermarket, at least in this case, is better. I think, well, hope, Moog is still good quality and not Chinesium.
Old 12-03-2022, 11:38 PM
this looks like the oem one i pulled off
this looks like the one i replaced it with
Quick Reply: Anyone ever heard this suspension noise before?
